Cylinder block gasket repair
Discussion in 'XJ Technical Chat' started by sybe, May 21, 2016.
  1. sybe
    sybe Active Member
    NYC - Brooklyn
    When i pulled the cylinder block off again to redo the orings (they now fit!). I accidentally torn a corner piece of the paper gasket. Is there some way to repair it without ordering a new one?
    Dab some Hylomar or other case sealer in that area to "glue" the torn gasket.
    sybe likes this.
  3. sybe
    sybe Active Member
    NYC - Brooklyn
    They told me to use RTV black head gasket sealer do you guys think that'll work?
  4. sybe
    sybe Active Member
    NYC - Brooklyn
    I just bought indian head gasket shellac compound to use for it. Hope it works.
  5. k-moe
    All the aove will work. The shellac will be a royal PITA to remove when it comes time, but you won't have any leaks in the meantime.
