Cylinder stud sheathing
Discussion in 'XJ Technical Chat' started by molochnik, Jan 7, 2020.
  1. molochnik
    molochnik New Member
    HiDez SoCal
    Does anyone happen to know why some of the front cylinder studs have a sheath on them? Is it necessary?
    After pulling the head and jugs, I was dismayed to find a whole lot of debris and heavily degraded sheaths on some front cylinder studs. The ones with the sheath also seem to be the most corroded of the bunch.
    What's this all about? I have never seen such a thing on an inline 4 before.
    it is a sound dampener IIRC.
    do you need it ?thats up to you.
  3. molochnik
    HiDez SoCal
    ^^^Thanks!
  4. XJ550H
    5 x cylinder stud SHEATHING.
    come as part of a kit
    We recommend the following accessory kits to compliment the above gasket kit:
    HCP21502 Aftermarket TOP END O-RINGS and CRUSH WASHERS KIT,
  5. molochnik
    HiDez SoCal
    ^^^Thanks again! At least I called them by the proper name :)
  6. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    you can use heat shrink tubing for that if you like , works well.
  7. molochnik
    HiDez SoCal
    I was considering that...wasn't sure if it would function the same.
  8. bensalf
    yorkshire ,england
    yes, its just to stop all the crud ,from rusting up the head studs. not to be used on the 2 oil gallery studs on the rh side of the motor
    stu
    Franz and molochnik like this.
