dead Starter motor
Discussion in 'Hangout Lounge' started by Flat4Ben, Feb 21, 2014.
  1. Flat4Ben
    Flat4Ben New Member
    quebec,qc
    I bought a 1980 XJ650, it bumstarts well, but the starter motor will not run, I have powered it directly from a well charged battery and nothing, so now I am trying to find out how to remove the starter without creating a desaster, I do not have any manuals to lead me.
    Thanks a lot
    Ben
  2. mwhite74
    mwhite74 Member
    Welcome F4B,
    Pick up a manual, blah blah blah :)
    It should spin if you connect a battery to it, but like any starter engine shouldn't be spun for any amount of time, esp with no load.
    Starter is held on with a couple of bolts, that's really about it, hopefully they come out with little trouble. Just make sure you keep track, where they are two different lengths. You probably just need to give it a good cleaning and perhaps change your brushes. Check this link out, a few pics in there to let you know what you're getting yourself into.
    http://xjbikes.com/Forums/viewtopic/t=4 ... +side.html
    Marcel
  3. Flat4Ben
    Flat4Ben New Member
    quebec,qc
    Hi Marcel
    Thanks for your answer, so I presume that at the end of the starter motor, there is a gear that pushes out when the motor si activated, like in a car starter. also when i pull the motor out no parts will come loose.
    Ben
  4. wingnut325
    wingnut325 Member
    Havelock North Carolina
    Nope. There is no bendix type movement of the starter shaft. There is a sprag clutch mounted in the starter gear inside the case.
  5. hogfiddles
    Two bolts at the butt end of the starter, one nut/washer to hold the wire on. Pull the starter out. The ONLY thing that can cause it to be stuck would be the rubber o-ring on the snout of the starter. The gears don't hook together, they just slide together. They only way that they could actually be hooked together would be if something broke and got snagged in there.
    dave
