Deleted Atari, no taillights without high beams now?
Discussion in 'XJ Technical Chat' started by JesseJames69, May 17, 2018.
  1. JesseJames69
    JesseJames69 New Member
    Watertown SD
    I removed the factory speedo unit. I did follow the thread to a t regarding what wire to jump to bypass the Atari warning indicators. Everything works now, except my tail light is acting strange. I have no idea what else to try. My tail light only comes on if my high beams are on. Otherwise, no tail light but brake lights do work. Also, if I do have the low beams on, when I apply the brake, my high beams turn until I release the brake. Any ideas as to what the issue could be?
  2. Jetfixer
    Yep you need to retrace your wires you have the low beam and rear brake light look at this and high beam some where your wires are crossed.
  3. XJ550H
  4. XJ550H
    did you hook headlight Y/G to tail light G/Y
  5. JesseJames69
    Watertown SD
    Yes that’s the diagram I used. No, the g/y is only spliced to the y/w. Then grounds to grounds , b to b/w and y to y/g from headlight. There are however two solid yellow wires
  6. XJ550H
    it would be the larger ga.wire look at the photo in link above
  7. XJ550H
    check your yellow wires one should have a white stripe sounds like you mixed them up large yellow is headlight smaller yellow/w is brake lights
  8. XJ550H
    b to b/w? I will assume you mean blue to blue/white L to L/w
    do you have a photo?
  9. Scottie1
    Scottie1 Active Member
    Columbia SC
    I followed the steps above and mine works fine. Only had to clean the connectors on the rear light.
