dies while riding
Discussion in 'XJ Technical Chat' started by bonafidehussler, Jul 20, 2013.
  1. bonafidehussler
    bonafidehussler New Member
    new york
    was riding and just dies mess with kick stand switch then she will go for a bit then die try to start and starts in nuetral put it in first and dies again mess with kick stand safety and ussallly runs for a bit then will die again any way to disable kick stand switch or is it something else maybe??
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    the switch is probably dirty or worn out. clean it + see if it gets better... if not, replace
  3. bigfitz52
    Disabling not recommended. Flush it out with contact cleaner.
  4. bonafidehussler
    new york
    could it be that or other problem???
  5. bigfitz52
    Well, since "messing with" it makes the problem come and go, and the symptoms are consistent with a flaky sidestand switch; I'd say you've got it diagnosed.
    It could be the wiring or one of the associated relays; but the switch itself is usually at the top of the "suspect list" because of where it's located.
  6. bonafidehussler
    new york
    cool thanks for the feedback greatly appreciated
