Diggin into the electrics
Discussion in 'XJ Modifications' started by hoss, May 26, 2009.
  1. hoss
    hoss New Member
    Minnesota
    Hey all,
    Finally got warm enough to get back out and work on the bike a bit. Got it to run for maybe thirty seconds last fall before it got to cold to be workin outside in an unheated garage. Now I want to replace the fuse block before I try starting it again. So today I picked up a new battery, fuse block, female spade connectors, and fuses. Just wondering if the fuse block I picked up will work or not. Says its good to 30 amps per cicuit. Only thing I'm not sure on is the common input stud. I hope it will work but if not could someone please let me know. Any help is greatly appreciated. Here's a link to the one I picked up. http://www.cooperbussmann.com/images/b7 ... 85efe9.JPG
  2. chacal
    It's not going to work without the addition of a relay.............otherwise, everything will be "hot" all the time!
    You need a 6-circuit in/out style box if you want to replace your original box correctly.
  3. hoss
    hoss New Member
    Minnesota
    Thanks for the quick response. I'll get a different one.
  4. woot
    woot Active Member
    I brought one such fuse box lately... one minute and I'll get the link
  5. woot
    woot Active Member
