Does anyone know what number CDI i should use?
Discussion in 'XJ Technical Chat' started by doublej, Nov 20, 2009.
  1. doublej
    doublej New Member
    Colonial Beach Virginia
    I have an 1981 xj650.I did a ground up on this bike and I dont have spark or a headlight.My coils are hot everything in the headlight seems to be hot but the headlight plug.I have a cdi off another bike but Im not sure its the right one if anyone can help.
  2. bigfitz52
    Isn't the '81 a TCI unit? I'd give you the numbers off mine but my 650 is an '82 Seca and I don't know if they're the same.
    The headlight isn't supposed to come on until the engine's running; that's normal behavior and OK.
    You may have a problem with one of the components of the safety circuit; if you unplug the safety relay and the bike starts then start wringing that out. Most common failure there is the sidestand switch because of its inhospitable location.
  3. SQLGuy
    SQLGuy Well-Known Member
    The SKU for the 81 Maxim 650 TCI is: 5V2-82305-10-00
    These are TCI based bikes. CDI units will not work on them unless you swap EVERYTHING (coils, pickups, adapt a rotor, ignitor, etc). And then you'd still probably have the wrong advance curve.
    This may help too: http://www.xjbikes.com/Forums/viewtopic ... tml#185964
    Cheers,
    Paul
