Does the airbox come out while motor is in?
Discussion in 'XJ Technical Chat' started by yamaman, May 18, 2009.
  1. yamaman
    yamaman Member
    Staten Island, NY
    82 XJ650RJ, I cracked my airbox at the boot edge of # 1 carb and could put some silicone on it but would replace the box if a good price came along. But I can't see how to get it out 8O . By the way, that was a few months ago, after leaving the boots in WD40 overnight I got all 4 on in 10 minutes today!
    Please, I'm only in 1st gear!
  2. wizard
    Some say you can get it out by distorting it, but I say it can't realisticaly be done with the engine in.
  3. bill
    bill Active Member
    Raleigh, NC
    So soaking in WD40 softened the rubber? I have never heard of that trick. The usual trick is the wrap them in a towel and place them in a dryer for a bit.
  4. mcrwt644
    mcrwt644 Member
    Winchester, VA
    Bill, dryer or microwave??
  5. bill
    bill Active Member
    Raleigh, NC
    Dryer have been the one I have heard (my boots are like new thankfully)
    You can even use a hair drier - just trying to warm them up but a hair drier cold get a spot too hot.
    If I was to use a microwave I'd use a wet paper towel and heat carefully. You wouldn't want to melt them.
  6. TIMEtoRIDE
  7. schmauster920
    schmauster920 Member
    Ventura, CA
    stumbled upon this some time ago on youtube.. its definitely possible.. just dont break those intake manifold bolts! (antisieze and 7.2ftlbs torque when you reinstall)
    http://www.youtube.com/watch?v=rfcKX29lSRk
  8. SQLGuy
    SQLGuy Well-Known Member
    This definitely belongs is a FAQ somewhere.
    The consensus seems to be that it is possible for the 650's and 550's. My personal experience is that it's not possible to remove the airbox intact from a 750 (SECA, at least) without removing the engine.
    Not sure about 900 or 1100 models.
  9. bigfitz52
    It's NOT possible on the 550 Seca; I've tried. Gotta pull the mill on those.
  10. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    i'm still thinking no for the 550 maxim, i put a good case of beer into trying and made no progress. luckily mine doesn't need to come out right now.
  11. yamaman
    yamaman Member
    Staten Island, NY
    so is this video suggesting you can't? Even the comments don't sum it up :roll:
  12. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I think the 750 Maxim will go in and out the same way. I'm going to try it here later this week and let you guys know for sure. Wish me luck
    MN
  13. yamaman
    yamaman Member
    Staten Island, NY
    I think I just realized :idea: the video ended by showing how to remove the airbox! instead of my first thought - he didn't get it in :oops: I'm good for that sort of crap
