drive shaft question!
Discussion in 'XJ Technical Chat' started by maxim-man, Aug 17, 2014.
  1. maxim-man
    maxim-man Member
    ontario canada
    So I have the swing arm off and need to order some bearings and seal from chacal! In the meantime I'm wondering what I have to do for maintenance with the shaft fluids! I know that I need to put some fluid in the secondary shaft side at the rear tire but I can't seem to find any info for the engine side of it! In pic below I assume grease goes in and around u joint?
  2. maxim-man
    maxim-man Member
    ontario canada
    What about this side of the u joint? I've seen some that have a fluid at this part that u can drain and change! For the life of me I can't find any info about this!
    Thanks!
  3. peganit2
    peganit2 Member
    Davison Mi
    NOTHING goes inside the bellows, it's just a cover for a pregreased and sealed u-joint. If you DO see grease or fluid in there, something is seriously wrong.
    On the forward side of that bellows is the engine/transmission oil.
  4. hogfiddles
    The u-joint get the greas smeared around it where you can work it to with you fingers . There's no oil bath for it, or the shaft. The far end of the shaft gets some grease where it fits into the rear hub. The u-joint and the shaft are dry just like under your truck.....only the bike's joint and shaft are protected by the boot and the swing arm housing.
    That's all.
    Dave
  5. maxim-man
    maxim-man Member
    ontario canada
    And that explains why I couldn't find any info! Lol
    Thx for your prompt response! This site rocks!!
    Cheers!
  6. Polock
    i put that big needle thing on my grease gun and pumped a few shots in the dust seals on the u-joint. don't know if it did anything but it made me feel better
  7. maxim-man
    maxim-man Member
    ontario canada
    As simple as that! Love it!
    Thx
  8. maxim-man
    maxim-man Member
    ontario canada
    Thx
  9. maxim-man
    maxim-man Member
    ontario canada
    Guess it couldn't do any harm! Lol
  10. bigfitz52
    Umm, excuse me? I haven't taken my shaftie that far apart yet, but the u-joint isn't DRY, and smearing grease on the outside won't do much. The critical lubrication in any u-joint is internal.
    Don't these u-joints have internal clips holding the cups into the yoke, so that they can be taken apart, cleaned, and properly re-lubed? Inside their bearing cups, where it matters?
    If so, that would be the maintenance to perform. If they don't come apart, shame on Yamaha. And we get to wait for 30-year old lube to fail.
  11. chacal
    No, they don't have clips, so shame is the order of the day (the bearing cups are staked/peened into the joint). But the bearings can be removed and new ones pressed on, and then the joint re-balanced. We do offer rebuilt joints that are ready-to-install.
  12. hogfiddles
    Fitz..... You're right but no can do with original ones. The reason for a smear of grease is simply so that as it turns MAYBE some will get worked in.... That's all. I know with cars and trucks you can get grease-able joints so I imagine Len would have a source for those too....
  13. chacal
    Nope, no greasable joints...........no provision for it in the casting. You could drill and tap them for a fitting, but that just seems too risky to us, you don't want a u-joint coming apart at 6000 rpms!
  14. maxim-man
    maxim-man Member
    ontario canada
    Heck no! I'm gonna order some parts from ya as soon as I get my shim deposit back! Orders from the wife lol!
