Driveshaft Removal
Discussion in 'XJ Technical Chat' started by 600ccmicrob1, Mar 6, 2009.
  1. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    What is the best way to remove the drive shaft on a xj650 to remove the engine? I could not find a definite answer while searching.
  2. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    I wish I knew. I'm getting ready to do the same thing on the same bike. I will be watching this post like a hawk. Do you have a pic of your 650?
  3. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    There are two in my gallery but I'm almost done with the cosmetics and it does not look like that anymore
  4. wizard
    You have to drop the swing arm, after unbolting the U/J inside the rubber boot.
  5. DianCecht
    DianCecht Member
    Central Illinois
    You can remove the engine with the swing arm still attached (obviously undoing the U Joint), but trust me in saying, it can be a whole hell of a lot easier by taking the swing arm assembly to the other side of the room... Mind you, when I did mine I was alone, but I kept getting the U Joint hung up when attempting to muscle out the engine. Removed the Swingarm, viola... easy peasy lemon squeezy.
  6. Jonmarkos
    Jonmarkos Member
    Omaha, Nebraska
    I left the drive shaft in the frame when I removed my engine. Just undo the spring that goes around the boot then remove the 4 bolts that connect the shaft to the engine. I was able to muscle the engine out without it getting caught up I just had to make sure the rubber boot was pushed out of the way.
  7. wizard
    The question from 600 was how to remove the drive shaft, pulling the swing arm is the way, why would you want to remove the mill?
  8. yamaha4life
    yamaha4life Member
    OH---IO
    wiz he wanted to know how to pull the driveshaft so he could pull the mill, is the way i'm reading it
  9. wizard
    I see what you mean, I thought he meant that the best way to pull the drive shaft was to remove the motor. :roll:
  10. yamaha4life
    yamaha4life Member
    OH---IO
    Come on wiz you should have played it off like" Well thats how we do it on this side of the Equator" see now you can use that one :D just helping a fellow brother out
  11. wizard
    Yeh, we've done all that hemispherical difference bit, like what order the pilot screw components go & what way the water goes down the plug hole. :lol:
  12. yamaha4life
    yamaha4life Member
    OH---IO
    :lol:
  13. 1982xj650seca
    1982xj650seca Member
    Atlanta
    can someone please tell me what size the swingarm bolts are?
    And do you by chance know what size the pivot bolt is (where front forks attach to the frame)?
  14. wizard
    22mm x 1.5 pitch 27mm socket & 1/4" allen key.
    not sure about part 2.
