Earplugs
Discussion in 'Hangout Lounge' started by engraverwilliam, Jul 25, 2014.
  1. engraverwilliam
    engraverwilliam Member
    Baldwin Hills, South Los Angeles
    I have been reading that lots of people use earplugs when they ride. I tried it today and wow what a difference it made in my ride. way more enjoyable and this during my commute on the 10 parking lot.
  2. mwhite74
    mwhite74 Member
    They say that noise is the biggest cause for fatigue while riding. I wear them when I have them handy, almost need to keep a pocket full of disposables...
  3. RonWagner
    RonWagner Member
    I wear them often, they definetly reduce faigue.
  4. Daed
    Daed New Member
    CNY
    I wear mine every time, its much nicer.
    Would recommend getting some made to fit your ear as well, so much better than foam ones.
  5. peganit2
    peganit2 Member
    Davison Mi
  6. foks
    foks Member
    the NL
    yeah, but only if I plan to go on the highway.
    at lower speeds I like hearing things. At the highway I certainly don't ;)
  7. peganit2
    peganit2 Member
    Davison Mi
    I live in ruraburbia, I hit 55+ on my own road.
  8. bostonbacon
    bostonbacon Member
    Boston
    I used Etymotics ER-20s. Started using that brand a long time ago for live sound work because I was doing lights and sound for 5+ hour shows and the foamy ones just weren't cutting the mustard.
    http://www.amazon.com/Etymotic-Research ... =etymotics
    You want the 'large fit' ones, the regular fit are for kids or those with small holes in their head!
    I started riding with a pair of earplugs on the highway a few weeks ago and was very surprised how pleasant it is.
  9. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I like the way my bike sounds. :D
  10. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    I was just thinking about this the other day, as I wear them whenever I'm not wearing my ff helmet. Just wondered if I was the only one who wore them... now I know I'm not. But considering that, at 65mph, wind noise can generate up to 103dB (a subway train @200' is 95dB, a train whistle @ 500' is 90dB) it makes sense if you want to protect your hearing, especially as you get older :p like the way my bike sounds too, but anything above 60mph and all I hear is the rush of the wind. Much more comfortable with the soft ear plugs in...
  11. engraverwilliam
    I actually hear more of the subtleties of the motor with the plugs in.
  12. mbrulla
    mbrulla New Member
    Sheboygan, WI
    Etymotics, as mentioned, are great...but you don't need to spend a lot on quality earplugs. I use Howard Leight Fusion (they come in a handy green plastic case). They're cheap (free from work along with 'clears') and, best of all, they are insanely comfortable.
    Etymotics I use for playing live/running sound as well, but on the bike I don't want to worry about $30 earplugs.
    engraverwilliam is also correct, you'll cut out a lot of the 'noise' frequencies by wearing plugs, which will allow you to hear your bike more clearly. It seems counter intuitive, but it's true! Try it out.
  13. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    +1 on the filtering effect!
    I don't wear plugs when riding (yet) - have a full faced helmet.
    However when I go to concerts these days I always wear earplug. My friends call me old (50 isn't old - is it?). But I would rather be old and be able to hear the concert clearly with out a bunch of cross harmonic noise blistering my ear drums.
    "Just because you can turn it up to 11 doesn't mean you should."
  14. hogfiddles
    I wear them most of the time--- that wind-whistle really gets bad quick
  15. mbrulla
    mbrulla New Member
    Sheboygan, WI
    I do if I know it's going to be especially poor sound (The Rave Bar, for instance)...but if it's a large enough venue I keep it wide open.
    If you're not doing something to protect your hearing while you ride you can expect to see your hearing diminish. Even semi-frequent exposure to high db levels while riding is enough to tarnish your hearing.
    Play it safe and wear the plugs (if you're not FF, of course...and make sure your FF is blocking adequate noise, too! My first one was louder than without due to whistling and poor seals).
  16. Polock
  17. sirpuma
    sirpuma Member
    Deer Park, WA
    I have bluetooth set up with my phone so I can take calls or listen to music. So I don't wear ear plugs.
