Electrical issues
Discussion in 'XJ Technical Chat' started by Hunter, Feb 20, 2013.
  1. Hunter
    Hunter New Member
    I just bought a doner 82 xj650, All wiring was pretty messed up. It is a bobber project. After hours of wiring this thing for head lights and tail, I got it to work....yea.... when i turn key to on position everything lights up, off nothing... good.
    Well now i am back to work on it today and same as before, but if i start the engine all lights go out.... turn off engine back on????
    Any suggestions?
  2. Folsoml
    Folsoml Member
    Tallahassee, Florida
    Welcome here! Unfortunately, I can't help with your problem, but you've come to the right place!
  3. MiGhost
    MiGhost Well-Known Member
    Without knowing the changes made in the wiring harness it would be nearly impossible to diagnose the problem. But it sounds like you have a relay wired incorrectly.
    Ghost
  4. Hunter
    Hunter New Member
    Actually I found it...had some wires crossed... Derr
    Thanks those who answered.
    Now......how hard is it to replace a clutch???
  5. bigfitz52
    Not hard.
    Have a look; read carefully. The 650s clutch is simpler than the ones specifically covered in the article; you won't have any tabbed plates or clutch boss spring to worry about: http://xjbikes.com/Forums/viewtopic/t=29541.html
    Otherwise the construction, and procedure are the same.
