electrical issues
Discussion in 'XJ Technical Chat' started by bpharoah47, Mar 31, 2008.
  1. bpharoah47
    bpharoah47 Member
    new york
    ok so my wiring harness is installed again but there are a couple things wrong
    all of the connectors are connected all of the colors match up
    but when i turn on a signal light all of the blinkers turn on without blinking
    until i cancel them
    also the headlight doesnt come on
    i am stumped
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    The headlight should come on when the bike is running when the voltage is higher. The flasher should do the same. If not check the charging system including the brushes on the altenator.
  3. bpharoah47
    bpharoah47 Member
    new york
    well if thats the case then maybe my problem has solved itself
    (the bike is in a garage i visit once a week, damned apartment life)
    thank you so much
