Engine Noise
Discussion in 'XJ Technical Chat' started by Shannonside, Feb 26, 2011.
  1. Shannonside
    Shannonside Member
    Hi all, a problem arising with my bike.
    There is a noise coming from the engine. Using a screwdriver as a stethoscope, I seem to be locating it right in the centre of the case, between the alternator and starter motor.
    It's like a whipping sound of a loose chain, but irregular. I drained the oil and went through it with a magnet, but found no particles at all. Nor any sign of a disintegrating guide.
    So. is it the Hy-Vo, or something else ? I wouldn't have thought that chain had much play.
    Is it possible that a carb out of balance could cause this ? I noticed once or twice that the engine sometimes kind of slaps and stumbles. This has even happened while the bike has been idling on the centre-stand for 5 minutes or so.
    Really appreciate anyone's thoughts...
  2. Shannonside
    Shannonside Member
    Sorry, thought I had done the signature thing correctly...
  3. waldo
    waldo Member
    San Jose, Ca. 95125
    If you could post a video with sound might help
  4. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Hey Shannon
    I posted on your other thread. When you put the 4 into 1 on did you replace the donuts that go between the header and the outlet?
    I've heard people mention hearing weird noises that turned out to be a poorly sealed exhaust. Plus, you should re-jet the carbs when going from a stock to a header as you will get a lean condition which could cause some serious engine damage.
  5. bigfitz52
    It would really help if we knew what bike you're talking about.
    The answers will be different depending on whether it's a chain-driven XJ or one of the shafties.
  6. Shannonside
    Shannonside Member
    Hi there Maxim-X, saw your post and thanks for it. As I said there, I have indeed changed out those four gaskets.
    Just looking over my notes, I think I've seen a big blunder. I set the pilot screws at 1.5 turns out, instead of 2.5 as specified in Haynes. Don't know why I did that :oops: In = lean, right ?
    bigfitz 52 wrote
  7. Shannonside
    Shannonside Member
    Hi, I'm willing but have no idea how to do that :lol: Will have a go maybe tomorrow, if I can find a tutorial online.
