Engine pcv
Discussion in 'XJ Modifications' started by Smoottie, Apr 8, 2013.
  1. Smoottie
    Smoottie New Member
    Warren, MI
    SO I recently eliminated the factory air box and installed 4 pods now I’m up to the challenge of tuning but what is the best way to go about the crank case vent should I make a bridge to distribute the vapor or should I just put a breather on it?
  2. Polock
    just put a breather on it, your going to have enough problems
  3. Smoottie
    Smoottie New Member
    Warren, MI
    problems? as in tuning problems?
    Yep. It seems to be a drawn out hit and miss methodology. At the very least save the carb to airbox boots and use them to mount the pods.
  5. Smoottie
    Smoottie New Member
    Warren, MI
    I might just stuff the box back in
  6. Smoottie
    Smoottie New Member
    Warren, MI
    well i put the air box back in couldn't get the pods to work o-well I need it to run like a top not look pretty
  7. hogfiddles
    Imagine that.
    Dave
  8. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    lol....
  9. Smoottie
    Smoottie New Member
    Warren, MI
    but on a awesome note after adjusting the carbs, syncing them and with the stock air box it starts so easy and runs better than ever
  10. bigfitz52
    Got your valves in spec yet?
  11. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    Yep, Fitz is right.... Get those valves adjusted first then do a colortune and sync.
