Euro Bar Swap - Maxim 650
Discussion in 'XJ Technical Chat' started by jayrodoh, Jan 28, 2015.
  1. jayrodoh
    jayrodoh YimYam
    Cleveland
    Stock bars are bent and I don't care for the looks of them. I would like to put Euro style bars on, has anyone done this swap? Wanted to see if there were tank clearance issues, wiring length, etc. I have to order new brake lines so that shouldn't be an issue. Will measure after the swap. Looking at something like the BikeMaster 15395.
    • Width = 30"
    • Rise = 2.4"
    • Pullback = 4.8"
    • Center = 4.8"
  2. KDub
    KDub Member
    Burnley, NW UK
    I put a similar bar on mine, but with a lower 1.5" rise. They didn't touch the tank, but I did need shorter cables and a shorter brake hose. I think I ended up using a 750 Seca Clutch cable (not in the picture) and just re-routed the stock Maxim choke and throttle cables. The brake hose was a left over from another bike I broke for spares (a Kawasaki GPZ 750 that had steel braided lines fitted). I don't recall wiring being a problem, I think I just looped it or stuffed it in the headlight bowl.
    It was a bit messy, but it worked.
  3. Hamster
    Hamster Member
    NW WA
    I did the same swap on my Maxim 750. At least I "think" they are those same bars, certainly similar dimensions. I did not replace any cables or brake lines. I did eliminate my "choke" cable and I re-routed everything else to use up a little of the extra length. I also lowered my headlight and gauges by 1 inch. All in all, the re-routing was a little fussy, but it was no problem and I am happy with the position, comfort and look. Before and after pix: IMG_7273.JPG IMG_7596.JPG .
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Thanks for the pictures guys. Nice job on the 750 Hamster! Looks good.
  5. Polock
    hay Hamster, that looks good you must have bought the big bucket of elbow grease :)
    kwes likes this.
  6. Hamster
    Hamster Member
    NW WA
    Thanks gentlemen. Yup, big bucket of elbow grease and a LOT of winter evenings drinking beer in the basement.
    Jayrodoh, I should have also mentioned that I replaced my front brake lever/master with one appropriate to the flatter bars.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    Was wondering about that too, figured I'd get the bars and then determine if that needs to be changed. Mines due for a rebuild so a replacement is not out of the question. What did you use?
  8. Hamster
    Hamster Member
    NW WA
    I was in the same situation. Long past time for a rebuild anyway, plus it looked really rough, so it was easy to justify getting a whole new unit. The bars really pretty much require it and I never mind springing for brakes and rubber. I got this one from MikesXS: https://www.mikesxs.net/product/08-0265.html But that's a 16mm piston for the dual disc. They have one just like it for the single disc (13mm). It is a very good match for the existing clutch lever.
  9. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I used them, absolutely no issues at all
    they fit great and feel just right!
  10. KDub
    KDub Member
    Burnley, NW UK
    That extra drop on the headlight looks mean. I need to get back in the garage!
