Exhaust Bolts XJ550
Discussion in 'XJ Technical Chat' started by broberg, Dec 28, 2012.
  1. broberg
    broberg Member
    Sweden, Östergötland
    Hi,
    Number 7 in this poor quality image, is it threaded in both ends? (I snapped two of them, so I'll need to replace them)
  2. moellear
    moellear Member
    Lima, Ohio
    yeah, its threaded both ends. check your Napa Auto Parts store. they may have the right size stud(s) or else you might be able to ask them if they make any?
  3. ktp1598
    ktp1598 Member
    Mount Washington
    Got a couple from the dealer. They're only a few bucks each.
  4. broberg
    broberg Member
    Thanks guys!
  5. mtnbikecrazy55
  6. broberg
    broberg Member
    Sounds good! I'll see if it's available in Europe, shipping liquids over seas isn't that easy.. I've noticed :p
  7. MiCarl
    Another option for removing them is heat. Those bosses the studs go into are well exposed and if you heat them the aluminum expands away from the stud and they should remove easily. Be careful not to heat the aluminum to melting though.....
  8. bigfitz52
    Since the holes are "blind" on the 550s (they don't go all the way through) the studs generally don't put up as much of a fight as they could if they were open on the backside. If there's enough left to get ahold of with a pair of vice-grips they should turn right out.
    When you replace them, replace them with studs again, not bolts.
