Exhaust
Discussion in 'Hangout Lounge' started by fakeplay, Mar 23, 2012.
  1. fakeplay
    fakeplay Member
    Newburyport, MA
    Does an xj650 exhaust system fit an xj750 ? Thanks
  2. MiGhost
    MiGhost Well-Known Member
    The easy answer is NO, but it can be done with a bit of adaptation on the muffler mounts.
    The critical part is to use the headpipes, and collector from the same model.
    The pipes will bolt up to the engine. Once you get to the mufflers is where the problems start.
    The problem is that the 650 Maxim used welded on mufflers with a different mounting point on the rear peg mount.
    This will be the point where you will need to fabricate something to attach the mufflers
    Ghost
  3. fakeplay
    fakeplay Member
    Newburyport, MA
    Oh. Thanks
