Feeler: Showroom stock '82 XJ650 Maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by JerseyDiesel, Mar 16, 2014.
  1. JerseyDiesel
    JerseyDiesel New Member
    I'm not sure what its worth. I probably wouldn't take less than $1000, but I think it's worth that. New tires, 24,000 miles. Very reliable. Adult owned/ridden. What do y'all think?
  2. hogfiddles
    Well, since you asked, here's what I think:
    I wouldn't call it Showroom stock----
    The grips are not original
    brake lever color has worn/bare spots
    Tank badge on at least the right side is missing
    Right side cover badge is missing
    Some oxidation is evident on some of the pipes, and the engine guard
    Appears to have some dings or swellings on the muffler
    Clearcoat is faded on the top of the fork slider
    Seat looks faded
    Rear shock spring looks oxidized
    What is the condition of the guage faces?
    Have you checked and adjusted the shim clearances?
    THAT all being said, I don't feel that the price is out of line, though..... if it's running, carbs cleaned, shims adjusted, brakes in top shape, clean title, etc......
    dave
  3. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    I would have to agree.... I would not call it showroom at all! If someone offers you $800 I would take it...
  4. Gunbunny
    Gunbunny Member
    CT
    Although a sharp looking bike, it's not showroom condition.
    I'd pay $1000 for an XJ that's solid & ready to ride, that includes tires (how old are they, how worn, etc.?) & brakes (how old are the lines, how bad are the pads & shoes, have they ever been serviced?).
    If the bike needs new lines, pads, valve shims, etc. (basic maintenance stuff), I'd be at $600 provided it runs & rides, probably because I'm going to put another $500 or so into it to make sure it's roadworthy.
    There is a LOT more to old motorcycles than looks. Not out to bash the bike, but it's the little stuff (that really actually is big stuff) that really adds up quick.
  5. bigfitz52
    If it starts, runs and (seemingly) rides fine, $800 max (as long as it makes good compression numbers.) It still needs all the "standard stuff" to properly recommission it.
  6. fintip
    fintip Member
    Austin
    As a SELLER (not a buyer), I would expect to be able to sell that for at least $1400, in Austin, Texas (context matters....).
  7. FtUp
    FtUp Well-Known Member
    pacific northwest
    I paid $800 for my 750 with 14k miles always stored indoors and very rust free. of course it needed brake and carb work and new tires.
    CN
  8. JerseyDiesel
    I said showroom stock, not showroom condition. It's been riden regularly since it was new. Just not ridden a lot. At least once a month since new. Always maintained, but not upgraded.
    It runs perfect, nothing wrong with it other than 32 years.
  9. motors-guitars
    motors-guitars Member
    Noblesville, IN
    i paid $750 for my 82 750 maxim last spring.
  10. bigfitz52
    There you have it.
    Not "wrong" but it's going to need brake lines, master cylinder and calipers rebuilt, new pads, rear shoes, clutch friction plates, fork seals, probably fork springs, rear shocks, valve cover gasket and "donuts" plus a few shims, new rubber bits in the carbs, tank badges and a lot of TLC before it's reliable enough to ride safely and use as intended.
    As I said, a proper recommissioning. Price tag: $600 ~$800 minimum.
    Add that to what you expect to get. Which is why I said $800 max.
  11. JerseyDiesel
    I appreciate all the advise.
    So, ask $1000 and take $800 is the plan.
    Thanks.
  12. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    JD,
    IMO our re-commissioned bikes don't sell for what they're actually worth. If you sell it to a list member as is you'll do good to get $800. If you sell it on E-bay, Craigslist or Other there is a possibility you could get more than $1k. As you know it will be unlikely the E-bay, Craigslist or Other buyer will know what is required to actually re-commission one (including the 6 ~ 8 bills). If you do not sell it to a list member IMO you should tell them about this Forum. There might be a hand full of these bikes out there in similar running condition and being as well kept maintenance wise as our bikes but again that is a very small percentage. Good Luck with the sell.
    Roc
  13. TIMEtoRIDE
    Spend about 2 hours detailing it before taking your "Craigslist" pictures.
    Blow a can of "Tire Foam" . . . pick an un-cluttered back ground . . .
