Finally got my clutch just right
Discussion in 'XJ Technical Chat' started by morg65, Mar 5, 2013.
  1. morg65
    morg65 Member
    Dublin Ireland
    Gang,
    Since I got me clutch sorted the knock from the drive shaft seemed to have gone away.Is it possible that the reason for the knock was due to a badly adjusted clutch.?
    Thanks all.
    Morg.
  2. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    What did you adjust with the clutch?
  3. morg65
    morg65 Member
    Dublin Ireland
    Hey Foolber.
    Thanks for the reply.
    There doesn't seem to be any stretch in the cable so i simply adjusted the lever end until I could find neutral easily... Small turns on the adjuster at a time..At one stage I had it so bad the gears were very hard to shift.
  4. 750E-II_29Rbloke
    South Cheshire, UK
    Sounds like, if your clutch was originally adjusted that slack then the clunk you heard could have been the gear dogs slamming into one another? Glad it's sorted :wink:
  5. chacal
    BTW, just saw the images of your bike in your gallery..............beautiful. Morg we're all jealous!
