Finally some good luck with a "bad" carb
Discussion in 'XJ Technical Chat' started by kjohnson, Mar 3, 2010.
  1. kjohnson
    kjohnson Member
    Wetaskiwin, AB, Canada
    Well ok, the whole carb on the XJ1100 wasn't bad. In fact it was working quite well with one exception: a buggered idle mix screw on the #1 carb. All the others came out easily while cleaning, but #1 basicly just shattered. Yes the screwdriver was a proper fit, made sure of that before I started.
    After attepting to get the srew out with heat, penetrants, oils and what was left of the top, I thought I was going to have to either replace the carb or just suffer with it as is.
    The idle mix needed to be set, so I decided I'll try easy-outs. I started with a 1/4" drill (just fits snugly in the reccess) bit to "flatten" out what was left of the top. Then I drilled down the middle of the screw with a 5/64" bit, basicly drilled about 3/4 of the threads worth deep. Inserted a #1 screw extractor/easy-out/whatever, gave it a tap and it came out just as easy as the other screws.
    Now all I have to do is wait for the replacement to get here so I can re-assemble everything completely. I feel a little better about the bike now and a little luckier in general.
    Now to train the 9 month old to put the tools back when he's done eating them...
