Fire Sale!!!!
Discussion in 'For Sale, Trade/Swap, Wanted' started by Fraps, Nov 8, 2011.
  1. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    Fire sale on 82 Yamaha XJ 650 RJ Seca parts and 82 Yamaha XJ 650 LJ Seca Turbo parts!
    Mostly turbo parts but lots of RJ parts too.
    Basically, I came home with yet another project bike (taking my total to 3) and the wife has issued the ultimatum! I have to lose one - the one being lost is the Turbo since it is mostly in pieces anyway.
    People - I have hundreds of parts that I need gone. No reasonable offer refused! Repeat - I just want them gone.
    If you are looking for that hard to find part - PM me and I bet I have it. First come first serve.
    This forum has been good to me over the years so you guys get first crack. Ebay gets the next crack. I'll put a detailed list together shortly.
    Thanks for reading.
    Rob
  2. hogfiddles
    You have GOT to be kidding........3?!?!?! only THREE!?!?!?? She's giving you the ultimatum to lose ONE?!?!?! I think I could tell you WITCH (oops) one to LOSE.........uh-oh------did I say that out loud? <G>
    She needs to see some of the other lists at the bottoms of signatures........oh, lets see........maybe..........mine, for example? Look at how many bikes have been rescued, restored, brought to glory, etc...... because of all of us!
    Too bad I don't have an rj.........................................yet.
    Dave Fox
  3. Fraps
    Fraps Member
    Yes - you have quite a lot of bikes in your sig! Single? :)
    Anyways - I've pretty much given up on the Turbo and just want to make some room in the garage.
    A few PM's coming in. So far, I have everything people have asked for. I'll be putting a picture package together for those that PM'd me so you can see what you're buying.
  4. Fraps
    Fraps Member
    So, as promised, here's a list of what's available. PM me if interested in anything. All turbo parts unless specified.
    RJ sissy bar assembly
    RJ Rear shocks
    Body and Frame
    LH lower panel fairing (x2) - silver and black
    RH lower panel fairing (x2) - silver and black
    RH upper panel (x2) - silver and black
    LH upper panel (x2) - silver and black
    LH console box
    Windshield and two hoods
    Front fender - black
    Gas tank cover fairing - black
    Rear molding - black
    Seat
    Exhaust pipes (x4)
    Exhaust collector
    Fork inner tubes (x2)
    Both mufflers
    Rotors (2 sets slotted)
    Pick up cover - NOS - unpainted
    Clutch covers (x2)
    Clutch cable (x2)
    LH side foot peg bracket - x2
    Side cover box
    Tray - over battery
    Side box - for locking chain
    Brake stabilizer bar
    Headlight nacelle
    Rear foot pegs
    Plastic handlebar cover w skirt
    Front foot pegs
    LH pickup covers - Yics
    Clutch cover w gear, cap, window
    Gear shift cover
    Brake calipers x2
    Front forks
    Air box
    Brake pedal
    "Seca Turbo" fairing badges - x2
    Electrical
    Headlamp
    Flasher relay (works for RJ as well)
    Battery sensor
    LH front signals - x2
    RH front signal
    Pickups
    Knock sensor
    Oil switch
    Neutral switch
    Gauge cluster
    TCI - x2
    Relays - assorted
    Rear turn signals
    Rear tail light
    Side stand switch
    Starter solenoid
    Wiring harness
    RH controls - startbutton kill sw
    LH controls - signals high beam horm
    Horns (x2)
    Fuel and Engine
    Gas tank with petcock and sender
    Fuel pressure regulator
    Fuel pump
    Carbs - w check valve and press reg
    Gear shifter
    Oil pump
    Surge tank w reed valve
    Manual cam tensioner
    Oil pan
    Cylinder head cover (says YICS)
    Seca turbo carb boots
    Valve caps and shims
    Pistons (67mm) w arms bearings pins
    Shifter drum
    Pistons - 63mm w wrist pins
    Throttle cable
    Tank vibration bushings
    Various gears, bearings etc. - too many to list.
    Sold and Pending
    Lower fairing fin
    Mirrors
    Oil cooler
    Air vents
    Camshaft covers
    Clutch basket
    2nd gear
    Gas cap
    Starter
    Coils
    Regulator
    Stator/generator
    Turbo
    Ignition
    Seat/helmet lock
    Oil supply check valve
    Rob
  5. Fraps
    Fraps Member
    Bump!
    Last chance at these parts.
    Rob
  6. oilheadron
    oilheadron Member
    Athens, AL
    Rob, do you have one of those plastic "650" caps that plug into the handlebar cover on the Turbos??
    What about the oil cooler cover that I tried to steal from slowboattochina?? 8)
    Do you have a good turbo (just in case)?? Sloboat hasn't started his bike up yet and it has quite a few miles on it.
  7. Ravenz07
    Ravenz07 Member
    Like to see your seat please!
  8. Fraps
    Fraps Member
    PM's sent!
  9. oilheadron
    oilheadron Member
    Athens, AL
    Just wanted to say that I bought some parts from Fraps and I'm extremely satisfied.
  10. Fraps
    Fraps Member
    Hey! Thanks Oilheadron!
  11. slowboattochina
    slowboattochina Member
    Madison, AL
    What is that rushing of air sound I hear? Almost sounds like someone sucking up!
  12. skw1972
    skw1972 Member
    Milton Florida
    the cutch cables the same for an RJ?
  13. hogfiddles
    No, not single. ......22yrs this coming summer. Once she got over being PO'd when I got my first bike, she got her own gear and started riding along with me (on the back, not on her own.......she won't do that). Then once she got past the "what, another one" phase, and the 'you can't have any more' phase, I was able to get her into the "I thought you said you were getting some bike parts, not parts bikes". Now things are at the "i don't know what he has, they come and they go" phase. I'm working on getting her to the "I don't know what's out there....I just ignore it all" phase.
    Work at it slowly, carefully, and methodically.....you'll get her there, too. It's only taken 10 years..............
    I even brought in two Raider snowmobiles a couple hours ago, and she didn't even say a thing. :)
    Dave
  14. skw1972
    skw1972 Member
    Milton Florida
    Dave is the man! thats what I'm trying to do!
  15. oilheadron
    oilheadron Member
    Athens, AL
    That's the sound of your non-running Turbo trying to suck its' carburetors back on. :D
  16. slowboattochina
    Madison, AL
