FJ600 - Can't get the Air Box back on straight!
Discussion in 'XJ Technical Chat' started by mreinsmith, Aug 25, 2012.
  1. mreinsmith
    mreinsmith New Member
    Southeast, PA
    Newbie to the Forum, Great people here, been readin posts for a while now. Thanks for having me!
    I'm a little frustrated right now so I thought I'd post for some suggestions.
    I can't seem to get the Darn Air Box back on straight and I was wondering if anyone had any suggestions for the best way to get them back on.
    I took them off because I'm having trouble with the idle and I thought it might be an air leak somewhere. They looked like they weren't on striaght in the first place. Now I can see why the PO didn't get them on straight either.
    Any suggestions/tricks would be helpful, in the meantime I'll keep trying to figure it out.
    M
  2. markie
    markie Member
    Suffolk, England
    I had the same problem. I took the air filter out and applied pressure to get the boots onto the two centre carbs first, with the help of a blunt screwdriver. Possibly a bicycle tyre lever is a good idea.
    I read on the forum that a quick (1 minute) bath in very hot water helps them return to their correct shape, before refitting.
  3. mreinsmith
    Southeast, PA
    Thanks! It's always nice to hear your not the only one having a problem :)
    Hand inside the box was a great idea, I also straightened out the clamps a bit and that seemed to helped. (they were causing them to pop off when you went to tighten them)
    However, I might yet have to try the hot water trick.
    Still at it because they popped off again on me GRRRR
    oh well, take a break and try again
    M
