Flasher Relay
Discussion in 'XJ Technical Chat' started by rhys, Nov 21, 2007.
  1. rhys
    rhys Member
    Columbia, MO
    So I figured out how to use the Search function on this site ;). I have found some good explanations and examples of getting generic flasher relays from AutoZone, OReilly, etc. That's all well and good. I have a freakin' degree in computer engineering (which has a strong emphasis in electrical engineering). I'm sure I can figure out the wiring and stuff.
    What I DON'T have a degree in is mechanical engineering. Most of the replacement relays don't have a nub like the stock ones for the little rubber mounting boot.
    So those of you who have replaced this relay, did you just zip tie the thing in place by the wires or... what? Epoxy? Use the Force? Let it dangle? Duct tape?
    The most reasonable (yet still rather silly) solution I have come up with is rubber bands, looped over a couple of times to get them taut. That requires checking and replacing them a lot, though. Rubber bands don't deal well with weather. Ideas?
  2. chacal
    Buy a used stock relay so you can use the rubber boot.........!
  3. rhys
    rhys Member
    Columbia, MO
    I feel a price check coming... ;)
  4. chacal
    HCP424VGU OEM Nippondense flasher RELAY, large relay marked FU257CD, 12.0V, 27W X 2 + 3.4W, 061300-5461, and DOT 6944 printed on it. Plugs into the connector with 3 wires going to it: Yellow with green tracer ("C" stamped on relay), Brown with white tracer ("L" stamped on relay), and Brown ("B" stamped on relay). Very good used condition, guaranteed to work! Correct for all XJ650/750/900 models.
    $ 9.00
    Plus shipping, of course!
  5. Robert
    Rhys, you are strong in the force... Care to make predictions for the next Power Ball numbers???
  6. rhys
    rhys Member
    Columbia, MO
    Strong in the force am I... but not that strong.
