Float Bowls became Waterfalls
Discussion in 'XJ Technical Chat' started by RefinedXJ, Mar 14, 2011.
  1. RefinedXJ
    RefinedXJ New Member
    After taking the bowls off for a cleaning, then replacing the gaskets and fuel line, Carb's #3 and 4, (Right side looking forward) both were pouring fuel out of the top while #1&2 stayed dry.
    Would this be a problem with the float settings or something deeper. I put on brand new gaskets and did not tinker with the floats at all, it's just been sitting with the bowls off upsidedown for about 6 weeks before my garage became habitable enough to sit in after the cold.
    I did get the bike to fire up (on all cylinders) before I cut it off, and then took the carbs off (pain in the ass) to try to investigate the problem.
    Has anyone else had problems like this?
    83 XJ550R ~20k Mikuni Carbs
  2. motorduck
    motorduck Member
    Chicago, IL
    I'm sure someone else will go into more detail, but when I had that happen to me, the problem was with both my float levels and my petcock.
  3. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    If they didn't leak before, I'd wack them with a rubber mallet. Sometimes small bits of crud gets into the float seats and the mallet helps remove it....but once you get it clear, install a fuel filter. Use your head though, don't beat them like a rented mule!!
    jeff
  4. bigfitz52
    Stuck floats, pure and simple (or crudded up float valves, same thing.)
    You're going to need to do a carb service. Not horribly difficult but you do need a manual.
  5. TIMEtoRIDE
    Sharpen a wooden golf Tee and ream the "seat" to polish it.
    Ultra-fine sandpaper on the float pin, AND the hollow part where it lives, to give the least friction.
    And of course, clean everything if they are apart, and wet-set the floats with the "clear-tube" method.
    If they don't leak on the bench, they won't leak on the bike.
  6. RefinedXJ
    I just threw in the towel and trailered my bike to my mechanic.
    He did tell me that one trick he uses is to take a q-tip in an electric drill, dip it in brass-x or chrome cleaner and then polish out each of the float pin seats.
    I probably could have fixed them, but with the temps over 70 in the forecast, I just wanted them done.
  7. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Now there's a good idea, never would have thought of that one, thanks!
    I wonder if one of these Dremel pointy polishers would be small enough:
  8. RickCoMatic
    One of the easiest way to "Re-finish" the Bore inn a Float Valve Seat is to acquire a Disc of 1500 Finishing Paper from an AutoBody Shop Supply Store.
    Cut one edge square.
    Roll the paper into a tight "Cigarette" roll.
    Twist the Roll in the Bore.
    6 to 10 revolutions ... dry.
    Brush on some WD-40.
    4 - 5 revolutions ... Wet.
    Cut-off the "Used" portion.
    Do the nest one, ...
    And so on ...
