Fork bolt won't tighten
Discussion in 'XJ Technical Chat' started by som1somwhere, Jun 8, 2013.
  1. som1somwhere
    som1somwhere Member
    United States, Illinois
    I went out and replaced my fork seals woohoo but not woohoo because on one of the forks the bottom bolt that holds the fork together wont tighten up all the way. it tightens to a certain point and the nut/bolt thing it bolts into inside the fork keeps spinning. is this fine or what should i do if not?
  2. som1somwhere
    som1somwhere Member
    nevermind it's solved. we cut the end of an allen key off and put a socket on it and tapped it with the impact alls good now :D
