Fork leak at top
Discussion in 'XJ Technical Chat' started by coffeyrt, May 25, 2012.
  1. coffeyrt
    coffeyrt Member
    Boston
    My left fork is leaking at the top near the cover where the schrader air valve is. I think it will most likely be o-ring #14 in the picture causing the leak, but I want to get opinions first before I dive in. Is this going to be an easy fix? Is this a sign of something more major than just an o-ring at the top?
      File size:
      31.2 KB
      437
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Your probably right that it is the o-ring
  3. coffeyrt
    coffeyrt Member
    Boston
    Thanks for the feedback. Would you know or does someone know what type of o-ring will be needed? Will a common rubber o-ring work or do I need buna because of the contact with oil
  4. maverickbr77
    maverickbr77 Member
    Lowville, New York
    i would go with one of the higher grade o-rings viton, buna whatever you can find local.
