Fork springs
Discussion in 'XJ Technical Chat' started by Marty82650, Oct 3, 2006.
  1. Marty82650
    Marty82650 Member
    Illinois
    Have any of you used the Progressive Suspension Front Fork Springs from Old Bike Barn? My forks need some attetion and won't hold air and bottom out. Will these springs take care of that?
    Marty
  2. Danilo
    Danilo Member
    Vancouver canada
    Maybthey would, but only after you have disassemble yer Forks resealed them and replaced the fork oil.
    Likely IF you did that (and you should) then your suspenders would not easily bottom out using 'just' the factory springs :)
  3. Altus
    Altus Active Member
    London, Ontario
    I've got the Progressives, and they're definately an improvement over stock!
    Now - resealing the forks and replacing the fork oil on the stock springs with the correct amount and possibly heavier wieght oil should take care of the bottoming, this is true. But the Progressive's are a performance upgrade, and well worth the money in my book.
