Forks
Discussion in 'Hangout Lounge' started by Flyingseca, Aug 18, 2012.
  1. Flyingseca
    Flyingseca Member
    Champaign il
    I have found a deal for a set of 81 750 seca forks. I was wondering would this be a direct bolt into my triple trees or hpw much would i need to change. Ireally want to have duel disk brakes.
    I know i would need all the brake hard ware like calipars and the larger master cylander.
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    no they are different diameters and lengths
  3. Flyingseca
    Flyingseca Member
    Champaign il
    So i would have to have the triple trees then would that bolt to my stem then
  4. bigfitz52
    You don't really need dual discs on a 550 Seca if you upgrade the original brake.
  5. wwj750
    wwj750 Member
    central minnesota
    I'm thinking you might run into problems finding the right master that will account for the 750's anti-dive configuration. If you want a dual disc setup. I'd go for one from a 650 Seca that is a lot less complicated. Just my 2 cents, good luck, let us know what you come up with.
  6. Flyingseca
    Flyingseca Member
    Champaign il
    Alright thank i was thinking of upgading to a slotted disk with steel braided lines but i figured that if the price was right why not. What brakes have you upgraded to fitz
  7. bigfitz52
    I used an EBC full-floating rotor with EBC pads and stainless steel lines; the improvement over stock is exponential:
  8. Flyingseca
    Flyingseca Member
    Champaign il
    That looks killer the po cut my front fender. How long is your line is it a single line or are you still using the junction. What seat is that.
    Thanks fitz
  9. Flyingseca
    Flyingseca Member
    Champaign il
    Where did you get the fork boots btw
