Frame fill
Discussion in 'XJ Modifications' started by zigzagzack, May 1, 2010.
  1. zigzagzack
    zigzagzack Member
    Malagash NS
    Just thinking, I am getting my frame powder coated and when
    I took the motor out and moved the frame around I notice
    some rusty water coming out of the drain holes.
    I was wondering when I get my frame back if I was to fill
    it with expansion foam if that would help it out by keeping
    the moisture out?
  2. Xplicit_XJ
    Xplicit_XJ Member
    Chetek, WI
    I assume that would help. If you end up doing that let me know how it goes I am very interested in how it turns out.
  3. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    I know literally nothing about that kind of stuff, but wouldn't the foam be flammable in case you needed to weld at a later time?
  4. zigzagzack
    zigzagzack Member
    Malagash NS
    Good point wonder if there is any non flamable
  5. tank
    tank Member
    SOUTH OF HELL
    You can get it in a non-flammable form they use it in houses all the time, you can get it at Home Depot or Lowes
  6. zigzagzack
    zigzagzack Member
    Malagash NS
    So has any one tried this or think it will work
  7. tank
    tank Member
    SOUTH OF HELL
    I have never tried it, but I don't see why it wouldn't work. I would take the frame completely apart to do it though, it might expand into places you don't want it to and with it apart you can trim away any unwanted foam
  8. motorduck
    motorduck Member
    Chicago, IL
    My concern with this would be - unless you can get the foam REALLY tightly packed in there, wouldn't it create crevices for water to get TRAPPED?
  9. Xplicit_XJ
    Xplicit_XJ Member
    Chetek, WI
    I think a possible way to minimize the risk of leaving pockets would be to make your own extension for the tube that comes with the foam can, run the tube all the way up the frame then back it out as you fill.
  10. Cooter
    Cooter Member
    Chi-Caw-Go
    The issue I see is that our frames flex, and you will never get the foam to seal the tubes completely.
  11. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I used the expansion foam to do much the same thing on a car years ago to find it actaully attracts moisture and made things worse. The drain holes are there for a reason (to let moisture out) The only way I see of stopping any rust that has occured over time would be to fog the inside of the frame with fogging oil and weld the holes shut maybe? Will it stop the frame from rusting if it already started? Can't answer that one. Just a thought.
  12. zigzagzack
    zigzagzack Member
    Malagash NS
    well think i'm gonna stay away from the foam ... sounds to iffy. My drain holes didn't work too well, there was water coming out of them. hmmmm
  13. Polock
    hang the frame from the steering neck and see what come out...yuck
  14. hogfiddles
    if there was water coming OUT of the drain holes, it would seem the me that they are working correctly then. You did say DRAIN holes, right?
  15. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    This may sound extreme, but if you were to "tap" a grease fitting into the drain hole then start pumping grease in until it starts coming out the top then I think it would displace any moisture and the grease would prevent further rusting. :)
  16. wizard
    Blast the inside of the frame with shop air to dry it, then get some WD40 or sim' in there, DON"T use foam, keep the inside clear for air circulation.
  17. Polock
    when you get it back from powdercoat it'll be dry
    the thing is to find how it's getting in, you don't fill your attic with foam because a shingle's missing :)
    my seca has a open end on the frame by the rear shock mount and a drain hole under the swingarm pivot cap, if that hole clogs the next place water goes is into the lower frame by the kickstand
    clean out the drains and plug the hole in the roof so it can't get in
  18. zigzagzack
    zigzagzack Member
    Malagash NS
    yes water did come out of the drain holes but only after lifting the frame up,
    i may put a couple more small holes in it.
    Grease wouldn't work i don't think, any little moisture and vibration would make the grease runny and may drip grease, may make a mess or get places you don't want it .
  19. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Grease sounds like a good idea in theory, but once the vibration get going and that grease oozes out? What if it gets on your tires or something? Sounds pretty risky to me. Why can't you dry it out with air and WD40 it like Wiz said and then just seal it up tight to keep moisture out? Just a thought.
  20. dwcopple
    dwcopple Active Member
    bay city, michigan
    Imagine how heavy that grease would make it...
  21. zigzagzack
    zigzagzack Member
    Malagash NS
    Not sure about sealing it especailly in my are close to the ocean. If the inner tubing sweats and turns to h2o then that would be bad
    thinking I'll keep Wd40 in it regularly and keep it well aired
