frame problems, maybe!
Discussion in 'Hangout Lounge' started by seca750, Apr 12, 2010.
  1. seca750
    seca750 Member
    New York
    Went for my first real ride on the bike today. When I got to my destination I noticed a leak. It looked like oil, but then I noticed a little drop of water on the frame. When I touched the drop it felt like something gave way and then more water came out of the frame. Alot of water! Should I be worried?
  2. RickCoMatic
    If this Frame problem is in the vicinity of the Side Stand ... it's alarming.
    Have the Frame repaired by a Professional.
  3. seca750
    seca750 Member
    New York
    It is. What am I looking at? The water that can out was clear.
  4. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Water gets in the frame sometimes and freezes over the winter. With that expansion you can run into the frame cracking. A buddy of mine on here is going to be doing a swap to a frame I gave him because he had the same problem.
  5. tank
    tank Member
    SOUTH OF HELL
    I just had to have mine repaired, had a crack right behind the kickstand. Cost thirty dollars to have it repaired, just make sure you find someone that knows what they are doing.
