Front Brake Master Cylinder question
Discussion in 'XJ Technical Chat' started by VTGanja420, Apr 30, 2016.
  1. VTGanja420
    VTGanja420 Member
    VT
    so after all my work ( and currently waiting for my tank sealing kit to set) ive come acrost an interesting conundrum, it doesnt work! xD, i ordered a replacement but a few hours after while i was looking through random (could use it if i had the cash) items, that the part i bough has wires coming off of it. my question is as follows, 1. does it need power to it to function ( similar to a car) or is it just a sensor that doesnt effect its function but is needed for inspection purposes? thanks again in advance :D
  2. Yardawg
    Yardawg Active Member
    Hatch NM
    It's a brake fluid level sensor. It's not necessary but if your computer monitoring system is working the LCD word "brake" will appear if those wires are not connected
  3. mrdawson
    mrdawson Active Member
    Wisconsin
    Depending on the MC that could just be the brake light switch also
    DrewUth and Yardawg like this.
  4. Yardawg
    Hatch NM
    That is true too
  5. VTGanja420
    VTGanja420 Member
    VT
    kk sweet, i was hoping it was something stupid like a sensor or a light wire :) my replacement should be here in the next day or so and my tank will be done coating and on this weekend :D. then the 2 days of meticulous paiting and taping xD. thanks for the info guys :D
    Yardawg likes this.
  6. VTGanja420
    VTGanja420 Member
    VT
    annnnd a cripling update, i got the brake resevoir and not the working part of the cylinder :mad: ugh ya know xD, always the 1 little thing holding ya back sometimes :p on the plus side this setback made me dl a pdf format haynes manual ( here the link, idk if its allowed here or not, but it already proved to be of use to me sofar :) ) * http://www.manualslib.com/manual/837861/Yamaha-Xj750.html * free dl and it works just fine :D just to assist yall where and when i can :) back to the grind!
