Front Brake Resvoir????
Discussion in 'XJ Technical Chat' started by wonderdawg, May 24, 2010.
  1. wonderdawg
    wonderdawg Member
    So. California
    8O
    I was doing some maintenance to my bike over the weekend and decided to check the front brake resevoir. However, I could not get one of the two screws out. I unfortunately mangled the screw head while trying to remove it. So, the question is how do I get it out and once I do what size screw do I replace it with? Also, will I need some sort of gasket to go under the resevoir lid???
    Regards,
    W. D.
  2. pauluminous
    pauluminous Member
    Vancouver, BC
  3. wonderdawg
    wonderdawg Member
    So. California
    Cool thanks for the info. I have hit it with the PB Blast. So I will try wiggling it out again perhaps tonight or tomorrow. Again thanks for the advice.
    Regards,
    W. D.
  4. RickCoMatic
    Both of the Screws on my 900's Brake Reservoir needed drilling out.
    Try a Hand Impact Driver, first.
    If you need to drill it. There's plenty of stock to oversize and retap for a new fastener.
    Don't forget to resize the holes on the Lid.
    Use a Single Hole Paper Punch too enlarge the Hole in the Gasket.
    Do the sight glass while you are doing all this work.
  5. cutlass79500
    lawrenceville georgia
    not trying to hijack the thred but someone overfilled my front brake resevoir and all the paint on the outside is peeling doesnt look like there is any leaks what would be good paint to use caliper paint?
  6. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    There is ALWAYS one screw that ruins EVERYTHING!, My 10 minute job is always 45 minutes because of one screw! I feel your pain...
  7. Jotr
    Jotr Member
    Ottawa, ON, Canada
    Rick, when you say "do the sight glass", do you mean replace it? if so...would appreciate some more deets on that...mines pretty weathered and cracked....but still holding.
  8. schmuckaholic
    California
    I think I tried that when I did my overhaul, and it didn't seem to help much.
    Yes, he does. Chacal stocks them, plus the black RTV you'll want to cement it in place.
  9. nkavanau
    nkavanau Member
    Vancouver BC
    Just had the same problem with mine. Drilled a small pilot hole , then took a drill large enough to take off the screwnhead. Pulled the top off and there was enough of the screw sticking out to get a small pair of plyers on, and they slid right out. New screws from the local Yamashop @ 93 cents each, and all is good again..
  10. wonderdawg
    wonderdawg Member
    So. California
    Okay so the screws can safely be drilled out is that the picture I am getting. Did not know the sight glass could be replaced, that is good to know as well. What type of adhesive do you reconmend to glue it back into place???
    Thanks for the info.
    Regards,
    W. D.
