Front brakes
Discussion in 'XJ Technical Chat' started by bigben750, Aug 9, 2006.
  1. bigben750
    bigben750 New Member
    Grand Rapids, MI
    I just purchased a XJ750J Maxim a couple of weeks ago. It has 10,600 miles on it and it runs ok, I think I need to clean and sync the carbs.
    My first question for now is: My front brakes are not releasing completely. I can still drive it and it moves great, even with my 6'7" 350lb body on it.
    When I put it on the center stand and lift the front tire up, it doesn't spin freely. It will spin a little then stop. The front brakes will stop me when I'm going down the road and pull the lever. Then I can continue when I release the lever.
    I'm wondering what I have to rebuild, the master cylinder, calipers, or both.
  2. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    I would suggest both if the bike has setting for awhile.
    In the Master cyl. you'll find a very small return hole be sure to clean it good.
  3. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I had this same problem. I had to rebuild my calipers which wasn't a bad job. I have been told that a little brake cleaner or degreaser on the calipers at the piston will help clean the gunk off and may allow them to retract like they should.
