Front Caliper swap on my Maxim X
Discussion in 'XJ Modifications' started by brille, Sep 10, 2010.
  1. brille
    brille New Member
    I am considering changing my calipers on my 86 Maxim x, I was thinking buying some yzf R1 or R6 brake calipers. Does anyone here have experience changing calipers on this modell, which calipers (year and modell) will fit :?:
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Why do you need to change them? The X brakes work prety good stock. I could just about do stoppies with my X and it had stock front brakes.
  3. brille
    brille New Member
    bigger, better, stronger 8) Seeing the price for R6 and R1 calipers on Ebay, its actually cheaper than most Steel-brakelines. (which I have installed aswell) It`s relative a cheap way to improve the brakes. I noticed that the R1 calipers on my fathers V-max had the same bolt holes as my Maxim, but I didn`t got a chance to try them on before he sold it. And since this is not an atempt to improve power and speed, but braking distance, I see all the more reason to do it. SAFETY :wink:
  4. darkfibre
    darkfibre Member
    Perth, Australia
    I Put R1 calipers, discs and master on my 750 seca. The Brakes and the amount of feel is amazing. Plus after changing the clutch lever setup, I can now buy the common R1 levers for my XJ even shorties :)
  5. brille
    brille New Member
    will the disc fit without mods? From what year R1 did you get it from?
