Front Fork disassembly
Discussion in 'XJ Technical Chat' started by Brewster_440, Jan 13, 2008.
  1. Brewster_440
    Brewster_440 Member
    Ormond Beach, FL
    I am changing the seals in the front forks of my XJ750 Maxim. I need to remove the allen head bolt at the bottom on the fork, which threads into the piston inside. The book (haynes workshop manual) says there is a yamaha tool, or you can make your own with a bolt and a piece of pipe. the other option is to use a piece of wooden dowel and jam it down inside.
    any ideas?
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    The tool is probably in your tool box and you just don't know it! You need a ratchet wrench, two long extensions and a spark plug socket. The spark plug socket needs to have a hex head at the end for a 7/8" wrench. The hex fitting inside the fork is 19mm which equates to 7/8". So just turn the socked around backwards on the extensions and slide it into position. Helps to have someone else on the other end to break the hex bolt loose while you hold the inner damper with the socket.
  3. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Good information to know. Is this typical on most Maxims?
  4. chacal
    Most models require you hold the damper rod "head" with SOMETHING or you'll never get the little retaining screw off the bottom of the forks (or put it back in and get it tightened again). Some forks used a damper rod with a 19mm inverted hex on the head (I know for sure that 650 Maxims do), and some use a larger 22mm hex...I haven't been able to figure out which models use which, so I made a special SOMETHING that will do either:
    w) Lower Fork Damper Rod Retaining Tool.....long aluminum tool with proper sized nuts on each to retain the top of the fork damper down in the bottom of the tube when removing or installing the dampers. One end has a 19mm hex and the other end has a 22mm hex, so it will fit all styles of XJ forks that require the use of this damper retaining tool.
    HCP4402 Fork Rod Damper Retaining Tool:
    $ 18.95
    http://www.xjbikes.com/Forums/viewtopic/t=2584.html
    Obviously, this tool will last a lifetime or two, and you can really impress all your other XJ friends when you're the only person on your block-town-city-county-state that not only knows about the special tool, but actually has one.......
  5. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I'll trade you for that rebuildable petcock I was telling you about. ;)
  6. Brewster_440
    Brewster_440 Member
    Ormond Beach, FL
    Thanks BlueMaxim. I did just what ya said. Went to my craftsman box, pulled out the 3/8 drive 5/8 spark plug socket (tested a 19mm socket on the drive end), pulled out a 24" extention and put the socket on backwards. sent it down the fork tube and it fit into the damper rod head!!! - i stuck a breaker bar on my new "special Yamaha tool" and loosened that friggin allen bolt right up!! Thanks again dude.
  7. BlueMaxim
    Central Mississippi
    I love it when I'm right! And you are most welcome Brewster.
  8. rtanner
    rtanner Member
    South East Michigan
    You can alco use the handle of a broom. Worked for me.
  9. MBrew
    MBrew Member
    Ft. Worth
    Darn! for a second I thought he was talking to me and I wasn't even involved in the conversation.
    Nice name Brewster,
    Mike Brewster (mbrew)
  10. chacal
    Great color on a '73 Trans-Am, too............
  11. ryan_975
    ryan_975 Member
    Conway, AR
    Not meaning to be rude and I hope it doesn't sound that way, but
    19mm ~ 3/4"
    22mm ~ 7/8"
    There are 25.4 millimeters in an inch so
    19mm/25.4 = 0.74803149606299212598425196850394" (just under two thousands less than 3/4")
    7/8" in decimal form is 0.875" x 25.4 = 22.225mm
  12. BlueMaxim
    Central Mississippi
    Not rude in the least. I should have not trusted my memory. Thanks for the correction.
