Fuel every where, please help
Discussion in 'XJ Technical Chat' started by Daveycrocket, Jul 26, 2006.
  1. Daveycrocket
    Daveycrocket New Member
    Traverse City MI
    so i bought my bike and got a new fuel pump starts and runs good its a 92 xj 600s but after about 20 sec of running gas just start leaking down from the carbs i think and everything is tightend and set to go just was wondering if anyone could shine some light
    dave
  2. geebake
    geebake Member
    Audubon, NJ
    I had a similar problem with an older XJ a while back. Turned out that the fuel line had come off the carb. Something to check.
    Good luck,
    Greg
  3. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I fit is an old fuel line, flex it and check it for cracks.
  4. 7-13
    7-13 Member
    New Hampshire USA
    This may not apply on your bike, but check the petcock. My 81 XJ has an ON, RES, and PRI. If it's set to PRI it dumps fuel.
  5. Daveycrocket
    Traverse City MI
    i tried all of that it looks like it is comming from the back of the carb is it possible that the gaskets dried out over a winter's sit?? or something else
  6. 7-13
    7-13 Member
    New Hampshire USA
    Those intake boots between the carbs and the jugs are expensive.
  7. MiCarl
    Can anyone tell me what ON, RES and PRI mean? I assume ON is on, RES is reserve, but what is PRI?
  8. hessenr00ts
    hessenr00ts Member
    Minneapolis, MN
    PRIME i'm pretty sure
  9. 7-13
    7-13 Member
    New Hampshire USA
  10. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    If your petcock is working correctly it will only flow fuel with vacuum applied in the on and res setting, when put in the prime position it will flow freely.
  11. Daveycrocket
    Traverse City MI
    so do u think i should just redo the carbs havnet done that beofre or just take it in how long does it take to do that do u think
  12. hessenr00ts
    hessenr00ts Member
    Minneapolis, MN
    I'd say it's not a bad idea. Depending on where the bike was ridden previously it could be kinda gummed up.
    The previous owner of my XJ rode the bike in S. Dakota for about a year, then let the bike sit for almost a year and a half. The dirt and dust had settled with the gas in the carbs and literally formed clay inside the carbs.
    I've little experience with such things and I needed the bike running ASAP (it's my only transportation) so I brought it to a garage. Took the mechanic 6 hours total to strip the carbs, power wash the entire assembly and put it back together.
