Fuel leaking from driveshaft boot!
Discussion in 'Hangout Lounge' started by jymmajama, Mar 14, 2011.
  1. jymmajama
    jymmajama New Member
    :x please help!! i own a 82 Yamaha Maxim xj750 and i have had it stored for the winter. i started it up today and fuel started to dump out the driveshaft boot. what is the problem?? how do i fix it??
  2. mlew
    mlew Well-Known Member
    Apex, NC
    The floats in the carbs are stuck open, sometimes a tap with a plastic hammer will set them free. If not its time to remove the carbs and give them a good cleaning and tune. Since the fuel made it to the driveshaft boot it is most likley in the oil, change you oil and filter before you run the engine. We don't want a dammaged engine.
