Fuel light addition
Discussion in 'Other Motorcycles' started by yamamax, Oct 3, 2006.
  1. yamamax
    yamamax Member
    Puget Sound, Washington
    I guess I'll start this with my disclaimer of "it's my wife's bike", although I do ride it occasionally because of the amazing mileage :D . Anyway, does anyone know if you can add a fuel light to a Virago 250 that doesn't have one currently. It looks like there is a spot for the light on the dash, but have to admit that I don't really know where the gauge fits into the tank (other than it's on the bottom somewhere) :p . I'm thinking that it might save me a few trips to bring her gas to get home to have a light. Brett
  2. SecaGirl
    SecaGirl Member
    Arizona
    Is the reserve not working?
    As for adding a light, you'd need to find if a larger Virago has it, and get the parts from that model. Your best bet would be to get the tank, sender, wires and light, at once. Maybe from a junkyard.
    If you tank doesn't have a sealed off mounting boss for the send, you'd have to cut one in. And nothing makes a welder dive for cover faster than someone carrying a gas tank into a weld shop! :shock:
    If you mod your tank, you might be able to get get a factory sending unit and get it mounted, the wiring would be pretty simple.
    Or take away the credit cards until she figures out how to work the reserve. :p (Gender loyalty be damed, it's pretty basic stuff!)
  3. yamamax
    yamamax Member
    Thanks for the tips. I will get online and see if I can find the parts diagrams for a few different Viragos to see if it will be a simple fit. I guess I can always use my Maxim as a reference for how it ties into the tank so I can see if it will be a simple addition.
    On your comments.....I agree that it is pretty basic stuff, I just also know that she doesn't pay much attention to the trip meter in the car or track mileage (which I'm anal about). If if's not a pretty simple plug and play operation (and reasonably cheap too), I think she'll just have to figure it out. :p
  4. robista361
    robista361 Member
    winslow, Maine
    another thing you could try is to reset the tripometer to zero when you fuel up. First you may have to see how far a tank of gas will get you through your regular driving routine before you need to use reserve. Use that distance as a guide as to when to fill up before you go to reserve.
  5. schmidtap
    schmidtap Member
    Ft Stewart, GA
    I use the fuel gage, and trip meter for mine, I squeeze out about 120-140 per tank, only down side of using the trip meter is I have had mine changed/messed with by kids and once for got to clear it
  6. RickCoMatic
    I just open the Gas Cap and take a little peek down in there. Maybe slosh the fuel around to see where the level is. Very un-scientific but effective.
    When in doubt; insert Gas spout.
    I'd rather get change for a Five than run-out of gas. Although, the Reserve on the Max got me 28-miles, between InterState gas stations, when the one I pulled-into was closed for the day.
  7. Pacocase
    Pacocase Member
    MD
    I reset the trip meter when I fill up. I know I can go about 150 during normal conditions before having to switch to my reserve, so I start looking for a station then. Sometimes it's more, sometimes it's less, but hey, that's what the reserve is for. I only had to switch over to it twice all year with that method.
  8. RickCoMatic
    Does anybody play "Russian Roulette."
    Beautiful day. Cruising along the Interstate; "Makin' time."
    All the rabbits you're chasing, seem to be dueling for the lead, in their exotic's.
    You just want to follow along and play.
    Time to Pit.
    There's a fuel stop, bathroom and snacks a few miles ahead.
    You downshift and hit your afterburners closing-in on the pack.
    The turn-off is just ahead.
    They don't stop!
    Neither do I ...
    I cut it so close, one time, that I rolled-up to the pump -- stalled-out -- having goosed-it good, when she first burped, for some momentum.
  9. robista361
    robista361 Member
    winslow, Maine
    I'm very familiar with that scenario RickO! with cars too!
