Fuel only reaching 3 cylinders
Discussion in 'XJ Technical Chat' started by pikeymick, Mar 25, 2009.
  1. pikeymick
    pikeymick New Member
    Wiltshire, UK
    Hello, I'm nearly there so I think to getting my baby on the road. But it's running on 3 at the moment. I have a spark on all 4, but the plug on pot no1 is showing no signs of fuel at all. I've stripped and cleaned the carbs/ rebuilt them so where do I go from here ?
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Can you open the carb drain crew on that carb and see if any gas comes out?
  3. TheHound
    TheHound Active Member
    Scotia, NY
    Your float in #1 could be set to high so it cuts off fuel before the bowl gets to fill.
  4. schmuckaholic
    California
    ...or the fuel rail between 1 and 2 is clogged. Unlikely, but that's the first thing that came to mind.
