Fuel pump
Discussion in 'XJ Modifications' started by wizard, Feb 16, 2011.
  1. wizard
    How about dumping the pet cock, vac line, floats x4, float valves & seats x4.
    Replace with 1 reservoir with level sensor & 1 electric fuel pump.
    Comments, introspection & productive discourse welcome.
  2. day7a1
    day7a1 Member
    San Diego, CA
    Thought about it, especially in relation to auxillary fuel tanks to add more fuel. You would still need the floats, float valves, and seats, unless you are talking about a fuel injection setup, which is already being discussed.
    I've considered how to use the same setup as a fuel gauge as an on/off switch. Seems it would work.
    However, although I am quite open to pure theoretical questions, one must ask before implementing an engineering design...."What is it's purpose?" For my thoughts, it was to ADD fuel capacity.
    What purpose would going to a single reservoir serve for you?
  3. wizard
    To stop a dozen reasons to flood the garage floor.
  4. darkfibre
    darkfibre Member
    Perth, Australia
    single reservoir across all the carbs would be impracticable on cornering due to fuel slosh etc
  5. day7a1
    day7a1 Member
    San Diego, CA
    Slosh can be contained by perforated baffles. Not a problem.
    Similarly not a problem: Clean up fuel. Easier than trying to install a fuel injection system.
  6. wizard
    Shoot, that would be some long bend.
  7. Alive
    Alive Active Member
    Queensland, Australia
    When you flood the garage... Post photos :)
  8. wizard
    Prevention is better than cure, Al.......
  9. Alive
    Alive Active Member
    Yea but I'm having a bad week and could do with the laugh :p
  10. wizard
    What's happening across the ditch, Al ? you Kiwis are coming over here in droves..........
  11. cutlass79500
    lawrenceville georgia
    wouldn't it just be easier to put a manual petcock on. Sounds a lot cheaper then designing your own fuel system. I would think if your smart enough to design all that your smart enough to shut it off. If you wanted to get away from that plumb a 1/4 inch 12v nc Asco valve in your fuel line soon as you turn off the key it closes. just make sure you don't have rust Thats all
  12. TIMEtoRIDE
    My random thoughts:
    Cornering would have no ill effects, unless you hang your butt off the seat.
    Parking on side-stand would flood a carb. Or drain safely into catch can.
    Some early 80's Japanese cars had a float that activated the electric fuel pump - I don't know how large that switch is.
    I've seen alot of carbs that have an overflow drain, that dumps down to the street. Most likely illegal today, but it could dump into a catch can that was continuously emptied back into the tank with a $20 Vacuum powered fuel pump available at BikeBandits.
    Interesting idea.
  13. Alive
    Alive Active Member
    Milk is more expensive than petrol, GST just went to 15%, everything is going up in price while wages remain the same, unemployment is at a 10 year high 6.8% and the govt are borrowing 300m a week... It's turning in to a rich mans paradise
  14. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    I installed a solenoid valve between my petc**k and fuel pump, I did it to prevent leakage past the pump. Mine is wired with the fuel pump so it's only open when the fuel pump is energized. You do not need to have a fuel pump to use the valve though. For you guys, there is no reason that you couldn't install the same valve and wire it to the "run" contact on your starter relay. That way when the bike is off, the valve closes. No runs, no drips, no errors!
    I think I paid $28 delivered, for the valve.
    jeff
    P.S. sorry about the pic, it's the only I have that shows the valve.
