Fuse panel replacement...
Discussion in 'XJ Modifications' started by KAOS, Aug 2, 2008.
  1. KAOS
    KAOS Member
    Newport, Maine
    I know I can buy a replacement panel from chacal! But I want 2 run my fuse panel 2 my headlight bezal 2 hide it.. N I'm sure a "fuse panel block" wouldn't fit in there... SO, My question is:
    I notice on chacal's fuse panel there's "2 extra" fuse slots. How would I wire in, Those "2 extra fuse slots"!?! Since I would need the 2 extra "slots" with my build...
    Thanx
    KAOS
  2. Snowdog
    Snowdog New Member
    Alberta Canada
    I did not look up the fuse panel but if it's like any other fuse panel all the slots are "HOT" on one side already. All you need to do is attach a wire to the other side of it and put in a fuse to use it.
    I'm a marine electrician by trade and thats how most all boat and car panels are set up.
    Marc
  3. chacal
    The fuse panels that I offer to not have a common hot buss, so you would have to run a (preferrably) switched hot lead from some other source to the "input" side of those two circuit slots, and then of course wiring from the output sides of those slots to whaatever you wish to power.
  4. wizard
    kaos, clarification please, are you going to re-possition the fuse panel from under the seat to the h-light?
  5. KAOS
    KAOS Member
    Newport, Maine
    *EDIT* I'm looking 2 get rid of the "old" fuse panel. N wire my fuses in my headlight bezal. Or wire 'em somewhere else so I can use a fuse panel..
    Thanx,
    KAOS
