gas all over
Discussion in 'Hangout Lounge' started by airborne82, Jan 21, 2011.
  1. airborne82
    airborne82 Member
    ATL
    I have a 550 seca, that was runing like a champ, but on my way to class I was coming up a hill when I started losing power. It sounded like it was flooded. I pulled over and gas was pouring out of the air-box drain hose. I opened the airbox but the filter had no gas on it just the in-between part. I then opened the oil cap, and smelled inside it, it smelled like gas. Dont know where to start, maybe a float? I also tried starting it again, and I would have to hold the throttle all the way down just to get it to idle.
  2. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Stuck float. Try tapping the float bowls to see if you can free it up. You are going to want to check the crankcase for fuel in the oil too. Time to clean those carbs.
  3. day7a1
    day7a1 Member
    San Diego, CA
    No, you already checked the crankcase for fuel in the oil...you need a oil flush to get it out...very bad juju.
    I agree it is likely the floats....not too hard to get to or to clean. Tapping them might work, but is generally a solution for an out of position float after a cleaning. Sticky won't be fixed by a tap.
    Take the carbs off, turn them over, and open the bowls. Look for a sticky float, clean all the floats...be careful not to bend the tang on the floats. While you have them off spend a couple of hours and a couple of cans of carb cleaner to clean the rest of the carbs too. You'll be glad you did.
  4. cutlass79500
    lawrenceville georgia
    I agree stuck float or a piece of trash stuck on the needle. For some reason there seems to be a run going on with floats sticking. Had 1 on my virago stick open Then a little while later the other stuck closed. I know its not trash in the fuel. The virago was hooked up to my external fuel supply
  5. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    ...all these reports of floats sticking, must have something to do with "El Niño" 8O
    :twisted: :twisted: :twisted:
  6. Jamie
    Jamie Member
    Norman, OK
    Yep, had the same problem, but not now. Got mine all torn apart and re-built, ultra sonic cleaned and looking like new.
  7. cutlass79500
    Jamie those carbs are to pretty to put gas in . Looks like you put new shaft seals in also good job
  8. Bushy
    Bushy Active Member
    Wasn't expecting to see porn here..
  9. bigfitz52
    VERY NICE WORK.
    Now back to the original problem:
    If your oil smells like gas, QUIT RUNNING THE BIKE until you've changed it!
    You've got a stuck float, almost for sure; plus you may have a petcock issue unless it only happens when the bike is running.
  10. cutlass79500
    to add to what fitz said it after you shut it off if its a stuck float any gas in the line thats higher then where the line from the carb to the main line is going to drain thru that carb into the intake system
