gas cap help please?
Discussion in 'XJ Technical Chat' started by mountaintrout, Oct 4, 2013.
  1. mountaintrout
    mountaintrout New Member
    cascade mt 59421
    does the xj require a vacuum cap or vented cap for an aftermarket tank? if so can you explain the function of the "vacuum"?
  2. hogfiddles
    you need a vented cap. The vent allows air to suck into the tank as the fuel leaves the tank. Otherwise, you'd end up with a vacuum inside the tank that will eventually get strong enough to overcome the diaphragm in the fuel valve. That will cause the fuel to stop flowing..........of course, you know that will cause the bike to stop running..
    Dave
  3. mountaintrout
    cascade mt 59421
    thank you very much for the help. great folks like you are hard to find
  4. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    You'll never find anyone like Hogfiddles. That's a government mandate.
