gas in oil....please advise
Discussion in 'XJ Technical Chat' started by Thee_oddball, Apr 27, 2009.
  1. Thee_oddball
    Thee_oddball Member
    I was was about to remover the side cover to get at the clutch and see if those steel balls needed Tobe put back...i started draining the oil and it came out like a fire house and reeking of gas, it had the consistency of water and about 60 ounces came out :( :evil: :( :evil: . i am thinking this is why the clutch stopped working and want to know should i take the cover off as planed and see if the plates have rusted together? or put the new 20/50 (for wet clutches) i bought in and turn it over a few times and let it sit over night?
    As for how the gas got there i have a few ideas..the day after i brought it home there was a big puddle of gas under the bike and i could see it leaking from the vac nipple on the left petcock, put the bike on the center stand and the leaking stopped...or so I thought, the day i pet the carbs on i took the tank off and thought it odd that it was stone empty, i just attributed it to the leak, but i geuss i better check the carbs to make sure the float pins are working even though no gas has leaked out of them at all since i went through them.
    thnx
    S!
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Hey Oddball your seat o-rings are bad. Pull the carbs and pop off the float bowls. Remove the floats and take the seats out. I'll bet they pull right out with no resistance. If thats the case a few new o-rings will get you back on the road. Use Shell rotella 15/40 in your engine.
    Didn't your mechanic tell you the fuel system was leaknig all over the place and it was a piece of junk??????
    Let us know
  3. Thee_oddball
    Thee_oddball Member
    thnx MN , i just put the new battery in and 2qt's of the 20/50 ,bike started right up and 1,2,3 are hot, 4 is Luke warm,,,but they are the original plug wires , i will pick up some of the 15/40 you recommended ( i saw it at the store but it didn't say it was for wet clutches )and a filter, if the clutch is still stuck off comes the cover :(:(.
    S!
  4. MN-Maxims
    Saint Paul, MN
    Let me know I'll help you best i can
  5. Thee_oddball
    Thee_oddball Member
    thnx bud
    no smoke the fuel system is Gebrochen...we have gazaline all over the place :)
