Gas Tank Rotisserie
Discussion in 'XJ Technical Chat' started by Smooooth, Dec 28, 2010.
  1. Smooooth
    Smooooth Member
    Syracuse, NY
  2. MiCarl
    Slick set up.
    They say necessity is the mother of invention but in my opinion it's a step-sister at best. Laziness is the true mother of invention :wink: .
    You're going to need to run it backwards so it cleans the other side of the frame tunnel. Right now the "abrasive" is pouring off and missing one side.
    Also would be a good idea to run it for periods at varying inclines so you don't just scour the deepest parts.
  3. Smooooth
    Smooooth Member
    Syracuse, NY
    I should have gone into deeper detail. I did apply 'Forward Thinking'
    Drill is reversible.
    Used Camera Tripod to facilitate changing the angle.
    Thank You
    Stephen
  4. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Yea! What MiCarl says!
    I think you have a great setup there! Never ever do anything by hand when you can get a machine to do the work for you!
    Most of the fun for me in this type project is overcoming the little issues as they come up. I should have been a manufacturing process engineer!
    Carry on!
    Loren
  5. RickCoMatic
    As soon as the Video started playing, ... I hit the Pause Button and came-back to the XJ-Site.
    This ain't a good idea.
    One thing goes south and that Tank obeys the Law of Gravity and drops to the floor.
    Where, ... there ain't even so much as a pillow-cushion from a nasty-old curb-sided easy chair to prevent the Tank from the big dent that its going to need having fixed roughly 0.16 of a second after breaking loose.
    Without any Safety considerations evident, ...
    See what I'm saying ...
  6. Smooooth
    Smooooth Member
    Syracuse, NY
    Mentally processing Ver. 2 considerations. Thank You.
    Slowly planning a dual axis system - more napkins needed........
    Stephen
  7. bigfitz52
    Can I ask a really dumb question?
    Why?
    What's in the tank that you feel the need to continually rotate it?
    Just asking. I tend to agree with Rick; seems like an overly elegant solution with disaster written on it. I would lean toward caution with an undented tank...
  8. Smooooth
    Smooooth Member
    Syracuse, NY
    Rust......
    Knocking as much of the loose stuff off before JBWeld and POR15 treatment.
    Pinhole syndrome on both back corners.
    Stephen
  9. bigfitz52
    Ahh; ok.
    What's in there knocking the rust loose?
    And I wouldn't recommend JBWeld. If you're going to all that trouble, take it somewhere and have it brazed/leaded (or even welded) up.
  10. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Dent prevention version 2.1
    Instead of placing a cushion below and having it bounce off and land beside it and dent. Duct tape a sleeping bag around it, then if it falls and for some reason the drill keeps going at least the sleeping bag will prevent it looking like a golf ball when you check it later in the day and find it's been bouncing around on the floor for a couple of hours! 8O
    :twisted: :twisted: :twisted:
  11. Smooooth
    Smooooth Member
    Syracuse, NY
    Thank You All..................
    By the time I finish engineering this to where it satisfies all parties - I will be able to offer this as a service.
    Hmmmmmmm - Interesting
    Thank You
    Stephen
    PS - Pulled out a few more napkins
  12. gennro
    gennro Member
    hhhhhhhhhhhhhhhhhhhh
    This seems a lot more work then using electrolysis to remove everything.
  13. Orange-n-Black
    Memphis Area
    Your wrong Smooooth, you'll never satisfy all parties. LOL
