Gasket question
Discussion in 'Hangout Lounge' started by fakeplay, Feb 4, 2012.
  1. fakeplay
    fakeplay Member
    Newburyport, MA
    Hi, I'm going to change my oil pan and cronkcase gaskets because I have a small leak down the kick stand. Can I just take the old gaskets off, clean the parts and just put the new gaskets on without putting on some kind of sealant ? I thought if you made the mating parts clean I could just replace the gaskets and torque them down. Thanks
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Yes and yes you can. That's what i've always done.
    You can buy instant gasket in a tube aswell, but i've never used it, though people are successful with it.
    There's no gasket on actual crankcase halves and something like Yamabond should be used though.
  3. fakeplay
    fakeplay Member
    Newburyport, MA
    I mean just the crank case cover. Thanks That's what I though.
  4. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Before you take off your oil pan, check to see if the bolts are tight. Also check the neutral switch and the oil level sensor. Check the shifter shaft seal, it may also be leaking.
  5. fakeplay
    fakeplay Member
    Newburyport, MA
    Bought a new seal too. Are the hard to remove ? (oil pan, cover ?) Also, do you think goo gone will clean everything good enough ? Ya, I'm full of questions today. Thanks
  6. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Hey buddy! you have the same bike as me. Goo Gone should be ok, I have used WD-40 to soften the gaskets. If it is still stubborn after a few hours of soaking try a scraper with a razor blade in it. The kind used to remove paint from window glass.
