Gauze Screen
Discussion in 'XJ Technical Chat' started by KINGOFZED, Mar 27, 2015.
  1. KINGOFZED
    KINGOFZED New Member
    Doylestown, PA
    1st post, and I still have zero miles on my XJ650J
    So, do I need the Gauze Screen. I'm doing a carb rebuild on a bike that has been sitting. When I got to the screen I noticed that one of the 4 is mangled and another is falling off the float needle seat. The rebuild kit doesn't come with a screen.
    I appreciate the help.
    Rob
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    just toss them and put an inline filter in the line form the tank.
    FU
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If you want them I'm sure Chacal has them. But, as FtUp said, a good inline filter will solve the problem and probably provide better protection anyway.
  4. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Meh, cheap protection, why not replace them?
  5. chacal
    Yes, we do have them, although there are a couple of different styles, depending on what float valves youa re using:
    fnv2) Aftermarket Hitachi fuel inlet - float valve needle seat FILTER SCREEN. These small mesh screen filters snap onto the top of the float needle valve seat and help to keep crud, junk, and other kinds of cosmic debris out of the carbs. These filter screens are included in some of the replacement float needle valve assemblies and lower end rebuild kits listed above; but, if you want to re-use your original valve seats, we still recommend the replacement of these screens. Fits all Hitachi HSC32 and HSC33 models carbs.
    NOTE: screens are not interchangeable between different style seats, since the style and diameter of the screen seat boss is different between each type of seat. Make sure that you properly identify which style seat you have before ordering replacement filters.
    HCP9855 Aftermarket Hitachi fuel inlet - float valve needle seat FLAT FILTER SCREEN, use one per carb, for use with float valve seats that have a 5.10mm screen boss (used on some original seats, and on the HCP1 aftermarket and the HCP10 oem seat assemblies). This style screen pushes straight onto the brass seat screen boss. Each:
    HCP9855SET4 Aftermarket Hitachi fuel inlet - float valve needle seat FLAT FILTER SCREENS, use one per carb, set of 4:
    HCP2644 Aftermarket Hitachi fuel inlet - float valve needle seat FLAT FILTER SCREEN, use one per carb, for use with float valve seats that have a 4.53mm screen boss (used on some original and aftermarket seats). This style screen pushes straight onto the brass seat screen boss. Each:
    HCP2644SET4 Aftermarket Hitachi fuel inlet - float valve needle seat FLAT FILTER SCREENS, use one per carb, set of 4:
    HCP869 Aftermarket Hitachi fuel inlet - float valve needle seat DOMED FILTER SCREEN, use one per carb, for use with float valve seats that have a a 6.57mm boss with a 7.30mm "capture lip" (used on many original seats and the HCP17176 aftermarket seats). This style screen "snaps" onto the capture lip of the brass seat screen boss. Each:
    HCP869SET4 Aftermarket Hitachi fuel inlet - float valve needle seat DOMED FILTER SCREENS, use one per carb, set of 4:
  6. KINGOFZED
    Doylestown, PA
    Thanks everyone. I don't feel like waiting for the screens to come in so I'll go with an inline filter.
  7. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Look here brother... Who you jivin' with that Cosmik Debris?
  8. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    They come in a few day from chacal
  9. Gulrok
    Gulrok Member
    Washington
    Beanie filters..
    and no you don't need them. Ditch for an inline .. in my own opinion...
