Going back to original exhaust
Discussion in 'XJ Technical Chat' started by Takencareofbusiness, Aug 14, 2014.
  1. Takencareofbusiness
    Takencareofbusiness Member
    North Vancouver BC
    Only my 3rd post to this forum.
    Can someone tell me if I remove my aftermarket exhaust 4-1, and replace it with an original 2-1 ( if that is the correct terminology), will my bike run differently?
    In other words, will I need to adjust my carbs?
    The original jets are still in place, I checked.
    The bike is running rich, the valves are in spec.
    I have only had this bike for a short while, and have not adjusted the carbs, just cleaned them.
    Thanks for the advice.
  2. hogfiddles
    You can't put a 2/1 on. You're bike is a 4 cyl, so you can only from a 4/1 to a 4/2.
    Dave.
  3. Polock
    When I changed from stock to 4/1 mine ran lean with stock jets
  4. Takencareofbusiness
    North Vancouver BC
    Sorry, you are correct with the 4-2.
    Still new to this.
    ok, so if it is running rich with an aftermarket exhaust, I can expect it to run slightly richer with stock exhaust?
    Can this be easily fixed?
  5. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    It is always easier to get the carbs right with a stock set up. If you have the stock jets, and they haven't been drilled larger, then you should have no problem getting it right with the stock exhaust. That said, it probably will require assuring the valves are correct, cleaning the carbs, and getting the sync and pilots adjusted. I am also assuming that you have the stock air filter and not pods.
  6. Takencareofbusiness
    North Vancouver BC
    Yes the valves are correct.
    I have cleaned the carbs.
    I have the original air filter.
    So, after installing the stock exhaust, I need to sync the carbs and adjust the pilot jets.
    Sounds simple enough.
    Thank you, this is great being able to get the answers you need from this site.
    I will be searching the forums for the correct procedures.
  7. bigfitz52
    You left out wet setting the float levels.
  8. tabaka45
    Brunswick, Georgia
    Yep! That's very critical. At least it was with my bike.
  9. Takencareofbusiness
    North Vancouver BC
    Another quick question.
    I have the used exhaust system that I ordered from Chris in Florida.
    Looks real nice, considering it is 32 years old.
    I have my order of new gaskets that I ordered from Len at XJ Forever.
    I sanded/ wire wheeled off what rust I could from the joints after I removed the old gaskets. This is mainly on the collector, both ends, but more on the interior side of header end.
    I used a wire wheel on a drill to remove all the rust I could. I "lightly" ground off the rust with a Dremel, on the inside of the pipes to remove the rust and scale.
    The header pipes look great, very little rust on the ends for the gaskets.
    The question I have is: can I use a smear of exhaust cement for inserting the new gaskets? Will this help take up any irregularities and fill the pits in the steel while helping to allow for final adjustments of the system while installing.
  10. Bushy
    Bushy Active Member
    Permatex and Loctite have high temp silicon type sealers suitable for exhausts. I had the loctite so that's what i used, works well no problems with it on 3 bikes.
  11. peganit2
    peganit2 Member
    Davison Mi
    A $1.89 tube of pure silicone from any hardware store is all you need. It is readily available.
    It can take the temps. PURE silicone, not any fancy "high temp" stuff from a parts store. Pure silicone is actually higher temp than that stuff. And far cheaper to boot. 8)
  12. k-moe
    Let me be the first to disagree. Check out the tech sheet for the stuff. Silicone sealers that are meeant for housing simply are not suitable for exhausts.
    http://www.dap.com/docs/tech/00000683.pdf
    Their copper sealant is even better in hing-heat conditions (700ºF).
    https://tds.us.henkel.com/NA/UT/HNAUTTDS.nsf/web/A0888AF3E133A169882571870000D837/$File/5920-EN.pdf
    Note the 400ºF service limit.
    Now check out the specs for a product that is engeneered for use on exhaust systems.
    http://www.permatex.com/documents/TDS/automotive/80335.pdf
    Note that the Permatex has a 2000ºF service limit.
    Loctite's high-temp RTV has a service limit of 600ºF, if you want a more flexible sealant.
    http://www.sds.loctite.com/product-search-1554.htm?nodeid=8797917544449
    The right tool for the job does not come from a Home Depot.
  13. peganit2
    peganit2 Member
    Davison Mi
    The source for my info is an OEM engineer.
    I'll stand by it until independant (non-moneyed) verification. (That engineer I am sourcing is one independant prick!)
  14. Krafty
    Krafty Member
    Point Clark ON
    I knew I guy like that once, just cause they're stubborn doesn't mean they're right.
    make your own decisions!
  15. peganit2
    peganit2 Member
    Davison Mi
    No!
    The engineer I refer to has had his hand in some MAJOR domestic automotive engine engineering decisions.
    He truly is brilliant, if more than a little ornery.
    I'll accept his word first.
  16. k-moe
    I like the manufacturers spec sheets myself. Hardly ever does a manufacturer underrate their own product, and I'm prety sure that DAP would slap a new label on their window caulk if they could cross-sell it for automotive applications.
  17. Krafty
    Krafty Member
    Point Clark ON
    we'll take your word for it,
    anyways ...yes using a small amount of an appropriate silicone product on your header flanges will help overcome minor irregularities in the fitment. always read and follow the directions for joint prep and set/curing times.
    don't want to ruin an otherwise perfect job by being too eager to hear it run.
    "just cause they're stubborn doesn't mean they're right. "
  18. peganit2
    peganit2 Member
    Davison Mi
    You could be Hillary Clinton!
  19. Krafty
    Krafty Member
    Point Clark ON
    and you could be Larry de Bug the cockroach
    "This is a true story it happened to a friend of a friend of mine."
    don't know if you guys got that show outside of canada
  20. peganit2
    peganit2 Member
    Davison Mi
    You're Canadien! I'm shocked!
  21. Krafty
    Krafty Member
    Point Clark ON
    you mean Canadian
  22. peganit2
    peganit2 Member
    Davison Mi
    I did not. 8) :lol:
  23. Takencareofbusiness
    North Vancouver BC
    Thanks for the tips and the " entertainment".
    I just wanted to make sure I was on the right track in thinking that I could put some permatex or equivalent that would produce a complete seal with the new gaskets and used exhaust, and help with the assembly process.
    I do not want leaks.
    As I keep reading on this site, "do it right-do it once."
    Yes, I will give the appropriate set up time.
    I am anxious to hear it run.
    Thanks to all of you, what a great resource to help us that are gaining the knowledge we need to get our bikes back into like new performance.
    BTW not really a Canadien fan.......but Price is one of my favourites, next to my boy (he's a goalie) who is playing University hockey this year
    "I AM CANADIAN"....only certain people know what this means, you know who you are
    Next project- upgrade the old fuse block to the new blade type which arrived from Chacal.
  24. Takencareofbusiness
    North Vancouver BC
    Had some time and installed the "new" exhaust today.
    Wow, what a difference in the sound.
    Sweet.
    However, now that the bike is so much quieter and sounds so good, I have discovered more noise.
    This sounds nasty.
    Sounds like a chain in the lower engine.
    MAJOR Rattles etc.
    Kind of goes away with increased revs.
    I hear the valves clicking away, but this sound I hear now, even tho it's been there before, just could not hear it.
    I would think it's what I've been reading about with other forums which talk about the chain guide disintegrating and need to split the case to repair.
    I know sounds are hard to diagnose over the forum, but some suggestions are appreciated.
    Also repaired the pet"rooster" .
    Thank you Bigfitz for the posting on repairing this.
    Added a new in line filter also.
    Thank you Chacal for the awesome service of the parts order, and ridiculously fast delivery!!!!,
    Could not have accomplished this install of the exhaust or repair to the petcock without all the help on this site.
    If this new noise is what I think it is, this will be disappointing, this will become a winter project.
  25. TIMEtoRIDE
    The time to pull the sump and look for particles and trash was when the exhaust was off (hindsight . . . )
    If you have a chain that is actually banging metal, you really shouldn't ride too much this season.
    You could try a cam-chain tensioner re-set (maybe??)
  26. Takencareofbusiness
    North Vancouver BC
    Time,
    Thanks for the suggestion.
    I'll look into this right now
