Going FROM pods to Stock airbox!
Discussion in 'XJ Technical Chat' started by broberg, Jul 4, 2013.
  1. broberg
    broberg Member
    Sweden, Östergötland
    Hi, Just wanted to get some input on my jetting.
    The bike is back together and have driven it a couple of km, not to far since it won't rev more then aprox 5-6k, loses all power after passing 4k rpm
    Anyhow, I didn't change the jets when I cleaned and rebuilt the carbs cause I wanted to see how it ran. And now I have so I'm going to replace them in the next couple of days.
    The previous owner ran cheap pods and a fairly open 4-1 exhaust. So he had fitted the carbs with these jets :
    Main Jet : #120 (vs stock #112.5)
    Pilot Jet : #40 (vs stock #35 XJ550)
    And this is clearly WAY to rich (my plugs are black and wet after a few km)
    now I'm running the 4-1 exhaust with a slightly more restricted flow due to the new muffler's small inlet and a stock airbox with a K&N airfilter.
    Should I go back to the stock jet sizes or maybe one size higher?
    Have a nice weekend all!
    I will sit and stare on my XJ until I get hold of the new jets 8)
  2. chacal
    Broberg, that's a really nice looking bike............great colour!
    The best thing to do would be to go back to stock sizes, and see how it performs in that environment. If you discover performance issues or detect an overly lean condition, then step things up from there, although with the K&N filter, you might find that you do have to go to a 37.5 pilot and maybe a 115 or 117.5 main fuel.
    Have you checked the main jet needle to make sure it is the stock size?
  3. broberg
    broberg Member
    Thanks Chacal!
    Okey, Where I start probably depends on if I can get the jets from a local seller or not (everything takes time when shipping stuff around the globe :p)
    I haven't checked the needle, are they marked or am I supposed to measure them?
  4. XJOE550
    XJOE550 Active Member
    Inverness, FL
    I wouldn't go back to stock. I would assume that if you have pods and a after market less restrictive exhaust and at least try the next size up on the pilots and mains. At least that is the assumption I would make, no guarantees.
    Here is a guide I found to rejet my other bike non-XJ:
    By the way, awesome looking bike. Most tastefully done cafe style I have seen in awhile. Most cafe stye conversions I have seen tend to be on the cheap and a bit rat-tish looking.
    Now in my case, I did not go as big on the main jet as the formula recommended. My model tended to be a little rich from the factory. Hope this helps.
  5. chacal
    The needles will be marked (engraved onto the upper portion of the shaft) with their "size"; for your model they should be 4GZ-3.
    By the way, the correct jet specs for a Euro XJ550 models are:
    Main fuel: 112.5
    Pilot fuel: 37.5
    Main air: 70
    Pilot air: 170
    Needle: 4GZ-3
    Main jet: O-8
    Fuel level: 2mm +/- 1mm
  6. broberg
    broberg Member
    Thank you! I was going for clean looking :)
    I just want to say that I have replaced the pods with the stock airbox, and not the other way around!
    Chacal, Thank you for the specs!
    I will check the needles tomorrow when I remove the carb rack from the bike.
  7. mtnbikecrazy55
    man. that is a BEAUTIFUL bike.
    In LOVE with it.
  8. adrian1
    adrian1 Active Member
    Nice bike. BTW how many goes does it take to turn aound with those Ace bars fitted?:)
  9. bigfitz52
    VERY nice. I'd put a chainguard back on it is all (the original was black.) Exceptionally tasteful color. Good job.
  10. broberg
    broberg Member
    Thank you! Yes, the chainguard is on it's way, it demanded some refurbishing first :)
    Actually not that bad, I had to fit a 4mm extension on the steering head stop, but other than that it's the same as before :)
    Thank you! I really appreciate your comments! :)
  11. mtnbikecrazy55
    May i ask how you cleaned/prepped/painted the engine?
    Thanks!
  12. broberg
    broberg Member
    It's not that clean actually, I just took the off as much corrosion I could of the fins, The bottom half of the engine was originally black, so I just did a clean and gave it a rattlecan touch-up.
    The covers where blasted with a plastic/alu mix to get the paint off (I bought a small blasting cabinet, one of hte best investments I've made!), and then sprayed with primer and matt black rattle can spray, it doesn't hold up so I'm going to respray them with 2k paint this winter. (same with the Mastercylinder and brackets for the levers, it flakes to easily)
    The valve cover however is powder coated.
  13. adrian1
    +1 on the chainguard and maybe just a tuning fork logo on the tank?
  14. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    NICE RIDE!
  15. TIMEtoRIDE
    But wait - -
    I thought that the Mikuni carbs had a jetting # reference different than the Hitachis.
    Meaning , you can't just get Hitachi replacement jets and toss them in a Mikuni Am I wrong on this?? It doesn't seem to be addressed in this thread
  16. broberg
    broberg Member
    Since it is a 550 with mikuni carbs we have not mentioned hitachi numbers in this thread (Maybe the # in XJOE550's pictures are, but They aren't for the xj550, just as guidline for jetting another bike).
    But no I don't think you could fit hitachi jets in mikuni carbs, they would probably have different outer dimensions. I have never touched a hitachi carb so I'm not 100%. But looking at the different types of jets just for the different mikunis out there I would say that all jets are probably are model or series related in shape.
  17. baz666
    baz666 Member
    Washington, DC
    Smart move. Pods are good but a hassle to set up. I put a set on an XJ900 and they worked fine after much trial and error but I don't think they helped produce much more power than the stock air box. Look cooler, I guess, but that's about it.
  18. broberg
    broberg Member
    Okey, checked the needles and what I can read it's 4GZ16, how off is that?
  19. chacal
    Well, I can't find anything on a 4GZ16 needle, it may have been some country-specific needle. The closest I can find is the North American XJ550 Seca needle:
    4GZ1: used on all North American XJ550 Seca carbs.
    Mikuni needle "numbering" systems are somewhat complex to describe, you can use some google-foo and come up with some more detailed info, such as this:
    http://www.jetsrus.com/a_jets_by_carbur ... ikuni.html
    which will give you some idea of the issue involved in analyzing Mikuni main jet needle "sizes".............
    In short, I think that the needles you have will be okay for your use, or, you can experiment yourself to death using other sizes..........
  20. broberg
    broberg Member
    Okey, I'll leave them in there for the time beeing :)
    Thank you all for the help and nice comments about my 550!
